Old 04-25-2011, 12:58 PM   #1
chimney chop
Question question.....1966 GMC sitting out in the elements for 7 years...........
another newb question:
how much would you estimate it would cost to get this truck up and running again? just looking for a ballpark estimate............
-1966 1/2 ton truck is complete.
only thing missing is the gas tank. (had gotten rusted out and then removed)
-had been fully restored, was running when parked 7 years ago.
-350 engine, 400 automatic transmission, aftermarket a/c.
chimney chop is offline   Reply With Quote
Old 04-25-2011, 02:35 PM   #2
Martin64
Martin64's Avatar
Re: question.....1966 GMC sitting out in the elements for 7 years...........
I'd be afraid to guess. It may just take a hose, a can of gas and a battery or every wire could have been chewed up by rodents...there's alot of information missing. Pictures would help also.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 04-25-2011, 02:40 PM   #3
chimney chop
here's a pic of the engine
Old 04-25-2011, 02:42 PM   #4
csa daddy
csa daddy's Avatar
shouldnt be much if it was already restored put new tank an fuel line on an give it a try an see if it starts. may need to rebuild carb an replace all old fuel filters
csa daddy is offline   Reply With Quote
Old 04-25-2011, 02:52 PM   #5
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Originally Posted by chimney chop View Post
...just looking for a ballpark estimate...
I'd say somewhere between $100 & $100,000 depending on how detail oriented you get with it. At least a ballpark figure for ya.
Really though. I agree with starting with the known stuff and follow up from there. I have to do the same with my Suburban. But I am swapping the motor and putting a fuel cell in. Good luck with the truck!
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 04-25-2011, 03:04 PM   #6
chimney chop
ha thanks, i actually haven't seen the truck in person.
it's in CA, I'm in TX.
that's the pic the guy sent me.
-so, what would be the absolute worst case?
i have about $2000 to put into it after the purchase.
as of right now i don't have many details other than what i've already mentioned.
-what do i need to find out before a purchase?
ps: i know these questions are incredibly naive, but hey that's where i'm at
appreciate your responses
Old 04-28-2011, 06:57 PM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
So what is it. IN Ca or Tx. Make up your mind.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-28-2011, 08:52 PM   #8
chimney chop
ha yeah, i got mixed up after looking at too many trucks
Old 04-25-2011, 03:07 PM   #9
Driveway Dreams
I have car A.D.D.
Based on the calculations I did for getting my Suburban road worthy including putting seats in, wheels & tires, dropping my motor and tranny in, and the fuel system...$2,000 should leave you plenty for getting it on the road.
-Gerald
Old 04-25-2011, 04:54 PM   #10
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Is this the truck your looking to ship?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-25-2011, 04:59 PM   #11
chimney chop
yup!
Old 04-26-2011, 01:10 AM   #12
mikie 1954
Where in CA is it , theres alot of guys here that may help out if close enough?
mikie 1954 is offline   Reply With Quote
Old 04-26-2011, 06:33 AM   #13
PGSigns
PGSigns's Avatar
I would have someone you trust go take a look. Couple of quick checks can tell a lot. Will it turn over with a good battery in it. Will it start if you pour a little gas in the carb, still have brakes and will it roll after you push on the brake pedal. Then just a good look at the entire truck top to bottom.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-26-2011, 07:41 AM   #14
Str8axle
Str8axle's Avatar
With $2000 to play with, I don't think you'll be over budget.
Ray
All my life, I've been told I'm a "Bad Influence"
Str8axle is offline   Reply With Quote
Old 04-26-2011, 01:25 PM   #15
markeb01
Senior Enthusiast
markeb01's Avatar
More than the cost to get it running, I’d want to make sure it’s something you want to buy. If it’s several states away I’d suggest you need to have someone you trust take a look at it (unless you personally know the seller). The pointers on the following thread can help. Sitting outside for 7 years can allow a lot of rust damage to occur in the usual areas if the vehicle wasn’t protected.
http://www.stovebolt.com/techtips/bu...uide_60_66.htm
Old 04-26-2011, 09:09 PM   #16
chimney chop
i'm a vehicular novice so........
when i go to see it how much should i offer?
what large concerns do you see?
ps: thanks for all your help guys!
Old 04-26-2011, 11:06 PM   #17
hamllik
hamllik's Avatar
The first thing to do is to take what ever the previous owner told you about the truck and throw it out the window. All old parked trucks just had a rebuild right before they were parked wink wink. The first thing I see is a newer clear coat paint job that has rust bubles coming through the paint, so it is going to need a paint job at the least and you have to wonder what they covered up. It is going to need that tire fixed to be loaded. If you are in texas why are you buying so far away? I have seen alot of trucks down there that are rust free in texas. You may be better off spending a little more money closer to home and save the shipping for repairs. Just my 2 cents I have seen alot of scams over the net and if you are a novice you are acceptable to them.
hamllik is offline   Reply With Quote
Old 04-26-2011, 11:09 PM   #18
hamllik
hamllik's Avatar
I just saw the rest of the pics I would be very concerned about it sitting without an air cleaner. I would offer no mor that 1000.00-1500.00 and that was after hearing it run.
Old 04-27-2011, 12:39 AM   #19
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
Well said! I learned the hard way about this. While I've had plenty of old cars in the past and should know better, I bought one over the internet anyways. I wouldn't say I got burned or scammed, but the rust was much worse than I originally thought.
These trucks rust out in every area of the body, and can happen anywhere in the country. My best advice is to buy something fairly clean & original. Even if it needs work, its still better than something that has been cobbled up by humans over the years.
Sorry for my rant, but you'll thank yourself later
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 04-27-2011, 12:09 AM   #20
collins10672
collins10672's Avatar
it has a chevy dash and tailgate with 65 chevy fender emblems,gmc grill and hood.
collins10672 is offline   Reply With Quote
Old 04-27-2011, 12:20 AM   #21
glendale
glendale's Avatar
i am confused it has texas plates? if its close to sac i can check it out for you.let me know.
glendale is offline   Reply With Quote
Old 04-27-2011, 12:22 AM   #22
chimney chop
oops, yeah this one's in texas.
looking at too many cars got me confused
Old 04-27-2011, 12:45 AM   #23
Slow Build
Slow Build's Avatar
I'm a bit leery of buying anything that has been sitting that long if I wasn't planning on a rebuild anyway. I bought a 98 Tahoe on ebay a couple years back that was advertised as "in pristine condition". Turns out that it sat out in a field for about a year and a half. A lot of seals and gaskets dried out causing leaks and other problems over the time I owned it. I bought it for $5000 but by the time I sold it I had $17,000 into it. Of that money only $1000 was in upgrades. The rest was fixing its problems. Ebay had a really bad system for grievances back then otherwise I would have returned it and gotten my money back. I realize there is a lot less to go wrong on the older trucks but I would still worry about seals and gaskets being dried out. Just my $.02 worth.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-27-2011, 01:04 AM   #24
rwgregory
That's a Chevy with a GMC grill and headlights. If the title says GMC run away quickly.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 04-27-2011, 01:19 AM   #25
chimney chop
why exactly?
the more and more i hear the more i think this is not a good project truck
