Old 04-25-2011, 08:37 PM   #1
crushermechanic
crushermechanic's Avatar
ignition bezel ?
is there a trick or special tool i need to remove the bezel and the whole switch. i was able to turn mine about 2 turns and it wont turn either way now.
crushermechanic is offline   Reply With Quote
Old 04-25-2011, 08:41 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: ignition bezel ?
Have you removed the ignition lock cylinder? It has to come out before the bezel will come off.
LockDoc
Leon
Old 04-25-2011, 08:44 PM   #3
crushermechanic
no i didnt pull it out. i may have already screwed up then. is there any way to remove the cylinder if it wont turn to the acc position?
Old 04-25-2011, 08:58 PM   #4
LockDoc
LockDoc's Avatar
No.
What is keeping it from turning?
LockDoc
Leon
Old 04-25-2011, 09:02 PM   #5
crushermechanic
i dont know it turned to the acc position one time right after i bought the truck and it hasnt turned any more. i need to replace the cylinder anyway because i want the doors to match keys.
Old 04-25-2011, 09:29 PM   #6
LockDoc
LockDoc's Avatar
What year is your truck?
Will the key turn to the on or start position?
Possibly the key isn't going in all the way. I would try spraying it with some penetrating oil and wiggle the key up and down as you insert it. Also try wiggling the key up and down slightly as you try to turn it.
LockDoc
Leon
Old 04-25-2011, 09:50 PM   #7
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
loc doc is the man on this chris
you still have that cab? I lost my cell phone out my hole in my floor so im really considering a new cab..lol
John
1999 Toyota Tacoma 4x4
Old 04-25-2011, 10:28 PM   #8
crushermechanic
it is a 71. it turns fine to start and run just not to acc position. i have sprayed it with pb before.
yea john i still have that cab. a buddy was coming to look at it 3 weeks ago and i havent seen him yet. first with cash gets it.
Old 04-25-2011, 10:31 PM   #9
crushermechanic
we can work something out i need to free up some green.
Old 04-25-2011, 10:41 PM   #10
LockDoc
LockDoc's Avatar
I would try wiggling the key up and down a little or pulling it out just a tad while you are turning it. If you can get it to turn to ACC follow the instructions below.
Turn the key to the left as far as it will go and insert a straightened paper clip or stiff wire into the hole in the face of the cylinder and “gently” push the spring loaded pin in. Turn the cylinder further to the left to remove it.
After you push the spring loaded pin in with the stiff wire and turn the cylinder further to the left you have to pull the wire out to finish turning it or it will bind. You can also turn it too far after you pull the wire out. That is when you have to wiggle the cylinder back and forth a little bit. If you wiggle it too much the pin will pop back out and you will have to start over. You should not have to put excessive turning pressure on it or push down hard on the spring loaded pin. Gentle and patience are the key words here...
LockDoc
Leon
Old 04-25-2011, 10:46 PM   #11
crushermechanic
thanks locdoc i will try that tomorrow. the cylinder is worn badly the key will come out with the key in any position and about any key will turn it.
Old 04-26-2011, 06:50 PM   #12
swierker
swierker's Avatar
Sorry about your phone, but this is funny
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
Old 04-27-2011, 12:45 AM   #13
dmack91
dmack91's Avatar
Mine did the same thing. Took some experimenting, but putting some side pressure on it allowed me to get the cylinder out (my key would come out in any position also). New key cylinder at NAPA was $7, but it wouldn't match your doors.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 04-27-2011, 12:07 AM   #14
wwotr
wwotr's Avatar
LockDoc
This is interesting because in my 72 GMC, it has NEVER gone into the ACC position. So is my switch screwed up?
I just never gave it any thought.
(Sorry...not meaning to Hijack the Thread).
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 04-27-2011, 12:36 AM   #15
LockDoc
LockDoc's Avatar
Unless your ignition switch was replaced with a '67 or early '68 switch it should have an accessory position.
Try turning it to the left using the instructions above.
LockDoc
Leon
Old 04-25-2011, 10:30 PM   #16
oldblue1968chevy
the price still the same?..
John
Old 04-26-2011, 08:24 PM   #17
oldblue1968chevy
Yeah, ol hubscub said 'the hole strikes again' my grandpaw lost his cane the other day out of it, yeah its that big
John
Old 04-26-2011, 09:17 PM   #18
crushermechanic
well i tried to get the cylinder out today. it turned left one time i put the pin in and turned further. when i tried to pull the cylinder out the key just pulled out. any other ideas. i have a parts truck with what looks like a new switch in it but no key for it.
Old 04-26-2011, 11:55 PM   #19
LockDoc
LockDoc's Avatar
Take the key out and bend a hook on the end of a piece of stiff wire, put it in the key hole and pull the lock cylinder out.
LockDoc
Leon
Old 04-26-2011, 09:57 PM   #20
oldblue1968chevy
I have some misc keys for GM..
Yeah stick a pin in the hole and turn left and maybe pull jiggle, it takes a bit of time maybe epoxy the key in there if you 'just GOTTA' get it out.??
John
Old 04-26-2011, 10:27 PM   #21
72lb4x4
Drill a 1/4" hole about 3/4" in. After that it will be pretty easy to remove the cylinder.
72lb4x4 is offline   Reply With Quote
