04-26-2011, 08:32 PM | #1 |
Exhaust Tip Location - Post Pics
My old truck is in need of a new exhaust. The shop says I will probably have to exit just in front of the back tires. I've got a 3/5 drop. Post some pics of your exhaust tips so I can get a better idea of what they look like in front of or behind the back tire. I've also got the Camaro tank installed so it limits the straight back exhaust.
Thanks,
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 Last edited by 67Slider; 04-26-2011 at 09:28 PM. |
04-26-2011, 08:45 PM | #2 |
Re: Exhaust Tip Location - Post Pics
Runnin bags and this is 2.5 inch mandrel exits thru cutouts in bumper
04-26-2011, 08:45 PM | #3 |
Grandpa in the rustmobile...
I ran some jeep springs awhile back 4 inch drop or so, and the mufflers hit the axle...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-26-2011, 08:47 PM | #4 |
I've got some glasspacks on there now and they are hitting the trailing arms. That's what is driving the new exhaust.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 Last edited by 67Slider; 04-26-2011 at 08:48 PM. |
04-26-2011, 08:59 PM | #5 |
I ran mine on the outside of the frame rails. Long tube Headers, 30" Cherry Bombs, 2-1/2" pipes running to back roll pan. Ended up cutting the exhaust off nearly flush with the roll pan, I didn't want the tips to stick down since everything looks smooth across the back.
Pretty stoked with the way it sounds too, here is a video clip Last edited by lakeroadster; 04-26-2011 at 09:01 PM. |
04-26-2011, 09:26 PM | #6 |
Lakeroadster,
Very nice! Sounds great too.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 Last edited by 67Slider; 04-26-2011 at 09:27 PM. |
04-26-2011, 09:32 PM | #7 |
BlahBlahBlah
Yeah I was thinking the same thing. Ive always gravitated to Flows, but those Cherry Bombs sound really mean!
04-26-2011, 09:33 PM | #8 |
Thanks!
I just didn't see the sense in running the exhaust through the control arms, around the shocks, over the axle, around the track arm and around the rear gas tank. Plenty of space between the frame and the tires... seemed the best way to run the exhaust and still allow maintenance access to suspension components. And less bends = less flow restriction But then again I always do things different. Last edited by lakeroadster; 04-27-2011 at 09:20 AM. |
04-26-2011, 09:02 PM | #9 | |
TILT COLUMN GURU
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
04-26-2011, 09:17 PM | #10 |
six inch drop and over the axle out the back...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
04-26-2011, 10:48 PM | #11 |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-27-2011, 08:55 AM | #12 |
3.5/5 drop here. Mine has 2.5" pipes and goes over the axle. My exhaust hits, but that's only because the dodo head that did my exhaust didn't know what he was doing. I need to have it redone and I'll get to it one of these days, but for now, it's not a big issue. It can be done. You just need to get a good exhaust shop with an experinced bender to do the work.
04-27-2011, 12:50 PM | #13 |
Registered Cruiser
I intend to live forever. So far, so good. |
04-27-2011, 01:02 PM | #14 |
Old Skool Club
Rob, sounds good. Sounds similar to mine, only I don't have a blower. What cam are you running? I like the exit on yours, too.
Do you have a sound clip of the dumps? Or, was that it?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
04-27-2011, 01:57 PM | #15 | |
Cam information: Competition cam - XR276HR-12 ----Operating Range:1800-5800 ----Duration Advertised:276° Intake/281° Exhaust ----Duration @ .050'':224° Intake/230° Exhaust ----Valve Lift:.503° Intake/.510° Exhaust ----Lobe Separation Angle:112° The motor is only 9:1. I have more information on it in my 68 S/C thread.
04-27-2011, 05:32 PM | #16 |
04-27-2011, 10:33 PM | #17 | |
Registered Cruiser
The bed's off so here's a look at how it's routed. It's got Long tube headers with 2.5" pipe. The mufflers are the biggest quietest OEM type that would fit under the cab. It's really quiet. All you hear is the intake which is pretty loud at WOT. The sound of it reminds me of a cop car. I like the quiet pipes. It's nice to not have to shout at your passenger on the highway. I shopped prices, and they were all over the map. I was quoted as high as $475, but I ended up paying $250, with me supplying new collectors. The guy was a wizard with his tubing bender. I'm not sure how many bends are there, but he did it with one piece of tube from the mufflers back. He and his helper had it done in just a little over an hour.
04-28-2011, 07:54 AM | #18 | |
04-28-2011, 05:56 AM | #19 |
Here's mine.
67 5.3L Build |
