Old 04-28-2011, 10:15 AM   #1
shuvl
shuvl's Avatar
64 c10 rear end question
Found casting marks N 3838227 GM5. Cannot locate "N" on any of the tables found on internet. When I spin the tire the drive shaft spins just a hair over two times. My first question is what gearing do I have? It's a straight 6, 3 speed on the column and I have 17 inch wheels. At 65mph I'm at 3200 rpm. I'd like to increase my highway speeds and decrease my rpm's. Which gearing should I go with?
shuvl is offline   Reply With Quote
Old 04-28-2011, 11:50 AM   #2
PGSigns
PGSigns's Avatar
Re: 64 c10 rear end question
Going by the rpm I would say 3.73
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-28-2011, 02:20 PM   #3
MikeN
MikeN's Avatar
Almost 100% of 64-66 with 6-cyl and 3-sp manual are 3.73's.
MikeN is offline   Reply With Quote
Old 04-28-2011, 06:36 PM   #4
oldtrux
oldtrux's Avatar
i would leave the 373's and put in a 5 speed od trans imho!
oldtrux is offline   Reply With Quote
Old 04-28-2011, 07:31 PM   #5
shuvl
shuvl's Avatar
Well I took the cover off and found 4:11 gears and gear lube that didn't look like it had ever been changed. So if I want to keep the three speed what would y'all suggest I put in for gears?
Old 04-28-2011, 07:59 PM   #6
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
cheapest way would be to find a 3.07. better way is to do the OD. Best way is to do the 3.73 (a common gear in our trucks) AND the OD.
if I'm doing the math correctly:
if you are 3200@65 now, a .7 OD gives 2240@65. the 3.07 is like a .75 OD, giving almost 2400@65.
the 3.73+OD would yield ≈ 2000@65
my 3.07/700r4 (.7 OD) runs about 2000@75, more or less
Larry
fleetsidelarry is offline   Reply With Quote
Old 04-28-2011, 11:23 PM   #7
collins10672
collins10672's Avatar
the 3:07 was the highest gear available in the 64-66 trucks.kind of hard to find though.
collins10672 is offline   Reply With Quote
Old 04-29-2011, 02:22 AM   #8
Captainfab
60-66 Nut
The 3.42 gears are a good comprimise between the 3.73's and 3.07's
Old 04-29-2011, 02:12 PM   #9
jimmydean
jimmydean's Avatar
You could also go with a 67-69, I seem to find quite a few 3.07's around here.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-29-2011, 11:52 AM   #10
shuvl
shuvl's Avatar
Thanks for all the advice. That's why I like this group, its a plethora of knowledge and no BS attitudes.
Old 04-29-2011, 02:35 PM   #11
Clyde65
Clyde65's Avatar
If you go OD trans, pick the 3.73's if you can, if you steel a deal, 3.42's will also work with an OD trans.
I have heard that the 3.08's are better for 3speed tranny's, but I have no real experience with them other than my truck now has the 3.08's and a 4 speed, I would enjoy it more if there were 3.73's or at least 3.42's back there. the only reason I am staying with the 3.08's is because I just rebuilt the rear about 3 months b4 I did my LS swap and OD trans.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
