Old 03-26-2003, 07:28 PM   #1
Dads72
Help fast, please
Replacing the carrier bearing on a 72 LWB w/2-piece D.S.
Would like to do it tonight, but I need the truck tomorrow.
Is it a press fit?
If so, maybe I'll wait.
Dads72 is offline   Reply With Quote
Old 03-26-2003, 08:58 PM   #2
crazy longhorn
Fabricate till you "puke"
yes, the bearing is a press.....crazyL
crazy longhorn is offline   Reply With Quote
Old 03-26-2003, 10:32 PM   #3
slam33
slam33's Avatar
Tight one's might need and puller, like a gear puller. There is a bolt thet holds the 2 pcs together, you need to loosen that but don't take it out, it's a b___h to get back in right. You should be able to knock it out in an hour.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 04-04-2003, 03:24 PM   #4
COBALT
COBALT's Avatar
Sorry for the late reply, but the inline bearing is a press fit but it's a loose one. I can pull it off with a set of 2-jaw pullers, and I can tap it back on with a piece of steel pipe and a cap that fits both on the inner race of the bearing AND over the end of the driveshaft where the yoke goes.
I originally made the mistake of having the bearing pressed on at the machine shop because I didn't think I could get it on. I found out later I could do it myself. The press isn't a tight one.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
