04-30-2011, 02:28 PM | #1 |
60-66 chevy pics with 73 to 87 front and rearend.
Anyone have pics of a 60-66 chevy with 73-87 front and rearend installed.
Thanks Jeff. |
04-30-2011, 02:56 PM | #2 |
Re: 60-66 chevy pics with 73 to 87 front and rearend.
As far as the front, most just do the a-arms and spindle swap and they usually dont do the rear since 73-87 rears are leaf spring and not coils. 71-72 would work best for both but are coming hard to find.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-01-2011, 10:06 AM | #3 |
Here's mine a while back
05-04-2011, 03:21 AM | #4 |
What size tires are those (ie 235/75/15)?
05-04-2011, 01:38 PM | #5 |
Jeff, I did the swap using a '75. I cut the brackets off both my '64 and '75 rears and welded the '64 stuff back onto the '75. As far as the frontend, I took the entire crossmember from the '75 and bolted it in place (with minor hole drilling/reaming). Like Clyde said, the '71-'72 stuff is getting rare.....
Here's a link to my website where I took as many pics as I could: http://home.mchsi.com/~bkndsdl1/rear_end_rebuild.htm Hope it helps!
-Mike from Alabama Why do we park on a driveway, and drive on a parkway? Jake - '67 Short Step Dirty Dan - '80 Short Fleet |
05-04-2011, 02:14 PM | #6 |
Thanks Mike. Those are very helpful pics. I think that is exactly the direction I plan on going. I have two half ton pickups in the backyard. 86 and 82 all with front and rear.
05-04-2011, 03:51 PM | #7 |
P275/60-15's on 15x8 rims
05-04-2011, 02:21 PM | #8 |
no prob, glad I could help. Just a note, I had the brackets TIG welded to avoid warpage. It might not be necessary, but I didn't want to take a chance warping it.
The 86 will have metric bolts and such. The 82 should be standard. I think the cutoff year was 83. Just a heads up.
05-04-2011, 02:51 PM | #9 |
I thought the metric didn't start until 88 but good info.
