Old 05-02-2011, 10:07 PM   #1
68short
68short's Avatar
Longbed to shortbed thread????
I plan to do the chop this weekend of the bed, and I was able to find one thread by rockcrln, but wasn't there another thread were they "z'" cut the frame? I did a search, but I must not be typing the right key words
Any help appreciated
68short is offline   Reply With Quote
Old 05-02-2011, 10:59 PM   #2
Ackattack
Ackattack's Avatar
Re: Longbed to shortbed thread????
I was thinking today while I was driving......
I shortened my truck too, and one of the time consuming parts of it is removing the cab. Anyways, I thing if you supported everything, you could unbolt the rear cab mount and cut the frame without removing the cab. You might loosen the front mounts and tip the cab forward a little, but that's about it.
Good luck!
Ackattack is offline   Reply With Quote
Old 05-03-2011, 09:19 AM   #3
Lemield
Lemield's Avatar
Here is the article I think you are looking for. I saw Bob's truck in person and he did a beautiful job shortening it.
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 05-03-2011, 01:34 PM   #4
72 tigger
72 tigger's Avatar
One thing I've done when altering a frame is to centerpunch the frame in (8) spots. If I need to remove 12" I will put (2) centerpunch marks 22" apart on the top & bottom of each frame rail before I start cutting - make sure your marks are the same distance at all (4) areas. After I've cut the frame & rolled it together I make sure my centerpunch marks are 10" at all (4) locations. This confirms everything is back in alignment (just 12" shorter). Hope this makes sense!
72 tigger is offline   Reply With Quote
Old 05-03-2011, 06:20 PM   #5
68short
68short's Avatar
Thanks for the tips and links fella's, looks like I might start the chop tomorrow or thursday
Old 05-07-2011, 09:40 PM   #6
68short
68short's Avatar
Old 05-11-2011, 09:55 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
nice job so far!!!
Old 05-12-2011, 07:22 PM   #8
68short
68short's Avatar
Originally Posted by VA72C10 View Post
nice job so far!!!
Thanks, Im real happy how its turning out, especially for never having any expierence replacing any kind of sheetmetal
Old 05-12-2011, 07:55 PM   #9
CowboyProtectionUnit
CowboyProtectionUnit's Avatar
Subscribed.... May Be doing this to my 87
Eric "Target" Sherwood
Professional Bullfighter For Hire
God Bless and Gods Speed!
TheCowBoyProtectionUnit@yahoo.com
http://www.facebook.com/pages/Eric-T...59496227444241
CowboyProtectionUnit is offline   Reply With Quote
Old 05-12-2011, 09:57 PM   #10
gcburdic
Restoration Virgin!
gcburdic's Avatar
just to add to this thread for a complete LWB to SWB conversion....here's LFD's bed shortening instructions.....
http://67-72chevytrucks.com/vboard/s...=223158&page=8 starts at post #195
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-15-2011, 05:42 PM   #11
68short
68short's Avatar
Yes that thread was very helpful to me. Here's where Im at with about 10 hrs invested.
Old 05-15-2011, 05:54 PM   #12
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I did my frame about a month ago. I didn't remove the cab, just the rear cab mounts, you can read about it in my build thread in my signature, look at post 19. I know that ebfabman did a great writeup on the process as well as nuke, I'll if I can find those for you.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-15-2011, 06:37 PM   #13
Jacfourteen
Here is a good one that I read before I did mine http://67-72chevytrucks.com/vboard/s...d.php?t=123624
also here is the one from nuke, start on post #19 its not real in depth but you can check it out http://67-72chevytrucks.com/vboard/s...ighlight=havoc
I thought that ebfabman did one but can't find it, maybe I was thinking of his videos that he sells, I haven't seen them but I'm sure they are great after seeing some of his work. hope this helps you out.
Old 05-15-2011, 07:08 PM   #14
68short
68short's Avatar
Thanks for those threads Jacfourteen.
Im actually going to cut the frame as the LFD build was done.
Old 05-15-2011, 07:03 PM   #15
BIGKEV
68short, what part of AZ are you in? I'm in Prescott!
BIGKEV is offline   Reply With Quote
Old 05-15-2011, 07:08 PM   #16
68short
68short's Avatar
Prescott Valley
Old 05-15-2011, 07:16 PM   #17
BIGKEV
Small world.
Old 05-15-2011, 07:23 PM   #18
68short
68short's Avatar
Well, hey there neighbor
Old 05-15-2011, 10:26 PM   #19
BIGKEV
I'd like to check this out some time being so close and all.
Old 05-15-2011, 11:49 PM   #20
68short
68short's Avatar
Absolutely BIGKEV, I sent you a pm
