05-03-2011, 06:50 AM | #1 |
Bracket for compressor on a 292
I am trying to work out how to fit air to my engine. We dont have much info down under.
I can make something but is there a quick bolt on fix? thanks
John Daley Melbourne, Australia 1946 Chev Ute 1977 Chev Tray Road racing sidecars |
05-03-2011, 08:15 AM | #2 |
Re: Bracket for compressor on a 292
They sold them with a/c, so they are out there. I'm not sure if a 250 bracket will work. Others will know whether you can use a 250 bracket.
Randy Summers Never brake in the learning curve! 1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737 |
05-03-2011, 09:10 AM | #3 |
I'd be looking at modifying a Holden or Valiant 6 AC Bracket to work on the 292
1979 C20 pickup 454 big block turbo 400, 4.56 gears |
05-03-2011, 10:42 AM | #4 |
The 292 uses unique to it brackets. There are at least 2 set ups, the long Delco and the radial. These pop up from time to time on ebay. The 250 brakcets will not work, the lowe rmounting is different between the 2.
My 77 250 has a York compressor, obviously a kit + homemade mounting. Key is to keep the compressor square and in line with the crank pulley. If you have Santucci's first book he calls out the accesory mounting holes on the RH head and block. There is a bolt on crank pulley (or you can make one pretty easily). You'll need more grooves on the water pump and/or alternator. My York kit has an idler mounted to the head in place of the PS (don't have it) to bypass the WP pulley, and 2-groove alternator pulley. Not my pictures, graciously donated by another board memeber. Here's a radial on a 250, you can sort of see where the brackets mount. You can see that a 292 with the fuel pump and motor mount swapped will not take the same lower bracket. The long Delco has to go higher to clear the distributor. My York mounts in the same place as this one, just a little higher, and has a brace that goes rearward.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors Last edited by D13; 05-03-2011 at 10:49 AM. |
05-03-2011, 06:20 PM | #5 |
Thank you
