Old 05-03-2011, 12:49 PM   #1
stepside85
stepside85's Avatar
4 Link Rear Bolt On.
I've searched online and here but can't seem to find a bolt in 4 link that's not bagged. I'm looking for a kit to convert my 85 gmc stepside to a four link with coil overs. Any idea where I can look?
1985 GMC S/S. Under complete reconstruction.
stepside85 is offline   Reply With Quote
Old 05-03-2011, 12:50 PM   #2
stepside85
stepside85's Avatar
Re: 4 Link Rear Bolt On.
Also will a 454 complete rearend fit my truck?
Old 05-04-2011, 12:28 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
There's no such things as a 454 rearend. The motor installed did not have a connection with the rear end option.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-03-2011, 05:46 PM   #4
stepside85
stepside85's Avatar
Damn, 40+ views and no responses. No love for the non baggers. I may just have to bag it.
Old 05-03-2011, 05:55 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
I haven't seen one. About the best you can do is take it to a chassis/racecar/fab shop that does good work and have them custom build one for your truck.
You can basically bolt any rear under these trucks, be it a 10, 12, or 14 bolt, as long as it's from 73-87. U joints may differ depending what rear is swapped under what truck.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 05-03-2011, 06:11 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Your going to have to run coilovers, or bags. Check with ou r forum vendors in the Suspension Marketplace. They will have what you need.
Old 05-03-2011, 06:14 PM   #7
silvereagle07
silvereagle07's Avatar
Here ya go. This will get you started. There are other options available. You may want to try the suspension section of the forum. Good luck. http://www.brotherstrucks.com/prodin...mber=4BK87BC-B
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 05-04-2011, 12:21 AM   #8
andrewmp6
That kit from brothers you weld it on the axle tho.Why do you want a 4 link tho ?
Old 05-04-2011, 12:56 AM   #9
BigBlocksRule
^ Maybe he's referring to a 454SS rearend?
BigBlocksRule is offline   Reply With Quote
Old 05-04-2011, 01:12 AM   #10
muthstryker
muthstryker's Avatar
CPP has a bolt on system that will get rid of your leaf springs. Its a truck arm setup like the 67-72 c10s.
muthstryker is offline   Reply With Quote
Old 05-09-2011, 07:41 PM   #11
stepside85
stepside85's Avatar
I'll do that. Searching only gave me bagged threads.
Nice. Thanks for the info
Better weight distribution than leaf springs, also less wheel spin I believe.
Yes I was. Thank you.
I'm gonna have to check that out. A 67-72 type suspension on a 85 would be pretty nice.
Old 05-09-2011, 09:39 PM   #12
mooseknuckles
mooseknuckles's Avatar
a lot of the bagged setups could easily be converted to coil overs, especially the air ride/ride tech ones...
mooseknuckles is offline   Reply With Quote
Old 05-09-2011, 10:01 PM   #13
BigBlocksRule
Be aware, the 454SS rearend uses larger axle tubes than a stock 12-bolt, fitment with the trailing arm suspension may be iffy...
Old 05-10-2011, 11:27 AM   #14
Tony@AirRideTech
Junior Member
Being that you are running a rear end out of a 454SS ( 14bolt Semi Float), you will not find anything that will be a complete piece of cake type bolt on system. Our bolt on kit is a super nice piece but our Panhard bar bracket is designed for either a GM Corp 10Bolt or 12 Bolt. So if you used our kit you would have to used a weld on Panhard bar axle bracket, you would have to enlarge the axle clam shell axle brackets for the larger diameter axle tube and you would need to weld the coil over mounts on. Not really too bad of a deal but there will be a little work to it.
Tony@AirRideTech is offline   Reply With Quote
