05-05-2011, 05:53 PM | #1 |
Brake Booster Size: Dual 8" vs Single 11"
I recently installed 4-wheel disk brakes onto my 64 with a kit from CPP. They supplied me with a dual-diaphragm, 8" booster. However I was wondering if I might actually get more power assist from a single 11" booster. I don't have clearance issues since I'm running a small block. Does anyone have any experience or thoughts?
Thanks.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
05-05-2011, 06:32 PM | #2 |
Re: Brake Booster Size: Dual 8" vs Single 11"
No, you won't get more power assist from a single 11" vs. a dual 8" booster. Its all about surface area, which increases exponentially with the dual. The 8" dual will generate more line pressure with the least amount of pedal effort. Also, a consideration besides clearance issues, is that the dual's are used when people want the power booster setup but have low vacuum caused by a big, long duration cam.
My vote, stick with the dual 8". |
05-05-2011, 06:43 PM | #3 |
Good advice. You will like the dual diaphragm better.
05-05-2011, 06:43 PM | #4 |
In reality they are almost the same.
Numbers don't lie.... Calculating diaphragm areas you get the following:
So..... yes the dual 8" is better, but by a negligible amount, about 5%. (In reality, by the time you remove the area for the actuator rod in the center, which the dual gets a double deduction for, the areas are probably identical.)No doubt that is why the 8" diameter was selected for the dual-diaphragm configuration. It gives about the same vacuum area as the single 11", but does it in a smaller package that better clears the valve covers of big block and LS motors. Hope that helps. John p.s.: I personally like the 11" better from an appearance standpoint, looks more "factory" correct, for whatever that's worth. Last edited by lakeroadster; 05-05-2011 at 07:00 PM. |
05-05-2011, 06:52 PM | #5 | |
05-05-2011, 07:02 PM | #6 |
Actually its about more just the surface area's. Any air that may get past the first seal is usually stopped by the second and the force is not lost. A single only has one chance.
05-05-2011, 07:07 PM | #7 | |
Force = Pressure x Area Last edited by lakeroadster; 05-05-2011 at 07:46 PM. |
05-06-2011, 11:22 AM | #8 |
Good call. Thanks for clearing that up. I really do learn something new everyday on this board
05-06-2011, 02:10 PM | #9 |
Hmmm. Here was my thinking, and the reason I asked:
Obviously the effective diameter of the diaphragms is smaller than the nominal case size, and the size of the second diaphragm on the 8" dual is even smaller than the primary. So I estimate: 8" Dual primary diameter=6" => Primary Area=28.27"^2 Secondary diam=5" => Secondary Area=19.63"^2 => Total Area=47.91"^2 11" Single Primary Diameter=9" => Primary Area=63.62"^2 => Total Area=63.62"^2 Therefore the 11" would actually have more effective force due to the larger effective diaphragm surface area. But CPP did tell me that the dual 8" was the best, so I'm confused.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! Last edited by argonaut; 05-06-2011 at 02:15 PM. |
