Old 05-05-2011, 11:46 PM   #1
turbobuick1
turbobuick1's Avatar
Alright guys, what's the real difference between 1/2 and 3/4 ton 67-72 trucks?
In terms of parts the factory put on? Are the control arms different? How are the frames different, if they are at all? How about steering knuckle/spindles? Brake calipers, master cylinder?
I've tried searching the board a little, I was hoping someone could point me towards a good reference. I wonder if the factory service manual specifies the differences?
Share the knowledge with a newbie guys!
turbobuick1 is offline   Reply With Quote
Old 05-06-2011, 02:02 AM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: Alright guys, what's the real difference between 1/2 and 3/4 ton 67-72 trucks?
The difference = .25 ton I may be wrong on this, but I will take a shot.
Control arms same with different bushings
3/4 ton frames are a little thicker (I think)
not sure about the steering
spindles, brakes,master cylinder are all different, more heavy duty on 3/4 ton
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 05-06-2011, 02:05 AM   #3
stich626
I don't really know, but by looking at the 3/4 trucks and my 1/2 ton
I'd say rear axle and springs haven't seen a 3/4 with coil springs.. in the rear..
frame, I'd think is the same, but again not sure..
I also never seen a 1/2 ton with rear leafs ..
tho. 73 up they all do..
stich626 is offline   Reply With Quote
Old 05-06-2011, 02:13 AM   #4
greenbd71
greenbd71's Avatar
I am interested also in this info. I have a 1972 3/4 ton custom fleetside. If parts are more heavy duty then I am glad I have one.
greenbd71 is offline   Reply With Quote
Old 05-06-2011, 05:48 AM   #5
60ratrod
yes, i do
60ratrod's Avatar
i've seen plenty of half tons with leafs. not all the half ton 67-72 chevy/gmc trucks got coils on all 4 corners. IIRC some half tons had 4 corner leafs. but the brakes, rear diff, spindles, and MC/prop valve were different along with the suspension, to allow hauling heavier loads
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 05-06-2011, 09:28 AM   #6
stich626
in my post I listed that 73 up where all leaf..
figuring he's asking about the 60-72 set up....
Old 05-06-2011, 07:23 AM   #7
Jessechop
I have a 68 coil sping 3/4 ton, these are the differences I see:
Rear axle
Spindles
Hubs/drums/brakes
Booster
8 lug
I assume the springs are different (heavier rating) but mine has different springs in it so I cant compare
Otherwise I think they are the same. My truck has been rebuilt with a good share of stock 1/2 ton parts with no issues what so ever
Jessechop is offline   Reply With Quote
Old 05-06-2011, 08:56 AM   #8
turbobuick1
Well just to help out a little I have a '72 Custom C-20 truck, and if you go on rockauto.com to look up parts for any vehicle, by clicking on the blue part number you can see what vehicles the part fits. I can see that between a 1/2 ton and 3/4 ton:
1) The master cylinders are different.
2) Rotors / Hubs are different.
3) Brake booster is different.
4) The upper control arms are different.
5) The lower control arms are different according to LMC trucks and Brothers trucks.
5) The rear coil springs are heavier duty, as are the front.
Frame differences? Steering Knuckle differences? I don't know.
And what about rear axles? I'm used to the newer 10 and 12 bolt rear ends, and I'm under the impression my truck has a Dana rear axle. What's the facts on 1/2 and 3/4 ton axles?
Old 05-06-2011, 09:42 AM   #9
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
The 3/4 ton frame is supposed to be made of slightly thicker material, though I've never checked mine to confirm. The frame has extra braces. If you've got drums all the way around, they are different front to back, and are a lot more powerful than 1/2t. Different master cylinder than 1/2. If you have rear coil springs, the control arm are reinforced. 4.10 ratio was as low as you could get (though I've read that some 4wd & big block could get 3.55 ratio in 3/4 ton). Full-floating axle in 3/4. And one of the cab mounts is different on 3/4. Other than that, body sheet metal and engine and transmission choices were the same.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 05-06-2011, 12:11 PM   #10
70truckguy
70truckguy's Avatar
I had a '69 3/4 ton side by side with my '70 1/2 ton. The front springs were taller, rear coils were thicker. The 3/4 had overload leaf springs on the back. I swapped springs to stiffen the ride. The front springs were either light or heavy from the factory (3/4 ton or big block were heavy). I did all of this 20 years ago when gm had factory parts available so it wasn't a problem to look it up. I remember the 3/4 ton having power brakes and 8 lugs, but can't recall anything else.
Rich
1970 C/10 Step, 383/700R4
http://67-72chevytrucks.com/vboard/s...d.php?t=466601
70truckguy is offline   Reply With Quote
Old 05-06-2011, 06:40 PM   #11
Shyguy
Junior Member
Shyguy's Avatar
The 3/4 ton rear cab mounts on the frame are lower so thicker bushings are used to give a smoother ride in the cab.
The 3/4 frame is slightly thicker.
The trailing arms has a plate on them for added strength.
There is extra frame bracing on the cross beam that the trailing arms bolted to.
I am sure there may be afew others, but I can not remember.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-06-2011, 08:44 PM   #12
Spoof
Spoof's Avatar
Sounds like a question for Special K.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 12-30-2012, 02:38 PM   #13
DaHos
DaHos's Avatar
ttt
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 12-30-2012, 02:56 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
For 4wd applications:
1) longer rear leaf springs for 3/4 ton
2) Dana 44 front for both with the "big hub" 8-lug for 3/4 ton
3) 12 bolt rear for 1/2 ton while 3/4 Chevy's came with an Eaton HO52 and 3/4 GMCs a Dana 60
Not sure if frames are thicker: I have both here will check
Old 12-30-2012, 02:57 PM   #15
darush01
my 72 custom 20 has all listed above and of course bigger wheels and tires I believe mine had 16.5 stock now has 16
darush01 is offline   Reply With Quote
Old 12-30-2012, 07:42 PM   #16
Mike C
Mike C's Avatar
I think all leafs were 52" eye to eye, regardless of 3/4 or 1/2, it wasn't until the later square bodies that the 56" leaves came on the scene.
Four wheel drives got 2 1/2" wide leaves while two wheel got 2 1/4". Whether 1/2 or 3/4 ton. The exception was the Longhorn trucks that had 2 1/2" wide springs. Balljoints and spindles different on 3/4 ton trucks in addition to aforementioned extra bracing, thicker frames, and completely different braking systems.
Most 3/4 ton Chevrolet's, as well as some GMC's, had the HO5200 Eaton while some received the HO7200. Most GMC's and some Chevrolets had the Dana 60. I've seen leaf and coil versions of both.
My two '70 GMC parts trucks both had 4.57 gears in their leaf spring rear Dana 60's. One was a 4 speed Longhorn with a 350 and the other a 6 cylinder 3 speed. The big block truck was a 7500 GVW truck while the Longhorn small block was 6600 and the 6 cylinder truck 6200.
I'm sure there are even more differences than those covered here.
My '70 Sierra Grande big block truck had 3.54 gears.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-30-2012, 08:30 PM   #17
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Mike C - no difference in leaf spring length 3/4 vs 1/2 T 4wd: 52" on a 3/4 ton HD spring here at home: 2.5" wide at narrowest point.
Old 12-30-2012, 08:37 PM   #18
Mike C
Mike C's Avatar
Another fact, 2 wheel drive trucks had spring perches on 42.5" spring centers while 4x4 had 40.5" spring centers. Once again, except Longhorns which also had 40.5" spring centers, so the Longhorn axle should be a bolt in 3/4 ton swap for a Blazer/Jimmy.
73-87 4x4 and 2x4 1/2 and 3/4 ton trucks had 42.5" spring centers while the one ton trucks were 40.5".
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-30-2012, 11:55 PM   #19
Longhorn 70
Longhorn 70's Avatar
As for the Longhorn compared to half ton, ball joints have larger diameter tapers as well as the tie rods so spindles are different. Bearings in the front, rear ends, and sway bars are heavier on the 3/4 ton. I have noticed the frames are heavier on the Longhorn but I don't know if the width and thickness are the same as other 3/4 tons.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 12-31-2012, 12:59 AM   #20
SS Tim
SS Tim's Avatar
Here are the frame section and modulus numbers, 39k psi carbon steel through C30s. Note the increased section height, flange width and thickness changes of the frame as the series step up.
C Blazer
C10 115
C10 127 6.04" height 2.53" flange width 0.156" thick 2.98 section modulus
C20 127 6.11" height 2.46" flange width 0.194" thick 3.71 section modulus
C30 133 C20/30 Longhorns 7.20" height 2.77" flange width 0.194" thick 5.05 section modulus
C30 157 8.18" height 2.97" flange width 0.224" thick 7.29 section modulus
K Blazer
K10 115 6.02" height 2.71" flange width 0.141" thick 2.70 section modulus
K10 127
K20 127 6.09" height 2.75" flange width 0.186" thick 3.48 section modulus
SS Tim is offline   Reply With Quote
Old 12-31-2012, 01:17 AM   #21
1972RedNeck
1972RedNeck's Avatar
That's a good frame.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
