Eaton H052 fluid capicity
Anyone know the fluid capicty of a Eaton H052? Pulling the center section out tomorrow to swap gears and want to make sure I buy enough oil
Re: Eaton H052 fluid capicity
Geez lemm know when you find that out. I need to do a flush cuz the gear oil looks weird. But ive been scratching my head on that too cuz that pumpkin is monstrous.
now accepting donations towards the cj needs hot rod parts fund. all applicable donators will be thanked hospitably with a 6 pack of any alcoholic beverage of their choosing. ![]() |
alittle over 2 and a half quarts
#4 | |
![]() Join Date: Feb 2011
Thanks, Paul Posted via Mobile Device
1969 C/20, 307, 4-speed, rusty with manual steering and brakes! |
4.10', 4.57, 5.13 and a few other lower ones. 3.90's are rumored, but i have never seen a set. I am taking my 4.56's out for the 4.10's.
#6 | |
#7 | |
![]() Join Date: Sep 2001
I think they use Yukon mostly. I think the opportunity to put new ones in may have ended a few years ago though...probably makes my axle a rarity.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
![]() Join Date: Jul 2016
What is best way to drain and change fluid in this aside from putting a hose in the fill plug hole? Is there a way to tell specifically what gear ratio you have?
#9 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
You didn't ask, but mine took 3 quarts of Mobil-1 full synthetic 75W-90. Got a new gasket and used Permatex 81182. It's made to use with gear oil -- good stuff. ![]()
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Cool, thank you for all the info! Have much trouble getting parts for it, (i.e. brakes, gaskets)? Recommended Supplier?
20' Daredevil (Ret)
Haven't needed much in the way of parts.
![]() Many years ago.... pocket bearing on the end of the pinion.... more recently, the (steel?) gaskets for the outer end of the axles.... brake shoes & wheel cylinders.... and the above mentioned diff cover gasket. All at my local Napa store.
Guess I need to get friendlier with local NAPA. Thanks.
![]() Join Date: Mar 2003
If the housing is completely dry, it can take up to a gallon of lube. Gear swap, ...upwards of 3 quarts
I think the 3.90's came out in the early 2k's. it was not cheap. and alot of nos parts were used up installing them in trucks. I dont exactly recall how much fluid the ho's use but I just did my rear and I thought it used about 4 qts.
that info would be in your owners manual |
#15 |
I'm getting smart with NAPA - surprised at some of their prices online are VERY competitive and availability of parts with "specialty" Shops like Classic & Brothers.
