Old 05-06-2011, 06:56 PM   #1
scum1
scum1's Avatar
tire and rm question
i have a set of 215/75-15 whites i wanna put on, but im gonna get some wheel vintique smoothies for the rear. should i run a 6 or an 8" rear rim...now i have 8 in the rear but with 225/75-15..would there be a problem runnin 8" rims with those new tires
scum1 is offline   Reply With Quote
Old 05-06-2011, 08:53 PM   #2
jocko
jocko's Avatar
Re: tire and rm question
if you have a choice - I'd go with a 6"-7" rim for 215s. If you want to save $ and use the 8" rims, it's a stretch (although I'm sure someone has done it successfully)- but might look like hot dogs stretched over a wagon wheel.
Here's a ref that says 5.5" to 7.5" for a 215/75. http://customwheelsmarket.com/rimwheelwidth1.html
But then again - I don't follow the recommendations either, I run 235/75/15s on a 5.5" rim - the opposite problem you have - too fat on a skinny.
Edit: Just re-read your post - if you are buying all new from WV's, I'd definitely go with 6" or 7" wheels. BUT - keep in mind any disk brake plans you may have for the future (or may already have installed), make sure any new wheels you buy are disk brake friendly. For instance, original 5.5 steelies do not fit over disk brakes. Just ask WV before you order, you'd probably be ok. Note that it is the inside shape of the wheel that causes disk interference, not necessarily just the rim width. Just ask WV before ordering, I'd guess that most of what they make has the disk brake inner profile though.
Old 05-06-2011, 09:48 PM   #3
scum1
scum1's Avatar
right on thanks for the response...ill do some research..these are the rims i was lookin at fyi
http://www.summitracing.com/parts/WVI-12-570604/
Old 05-06-2011, 09:56 PM   #4
jocko
jocko's Avatar
those are nice - and they should work just great with your 215s.
