![]() Join Date: Feb 2011
Question on a 1970 GMC Buckets Seats Install?
i have a 1970 gmc i wanna put bucket seats in what is the best way
is there a truck with seats i just pull them out and put in or do i need 2 just buy some aftermarket seats and make them fit? Last edited by 70cst; 05-08-2011 at 05:27 PM. |
Catchy title goes here..
![]() Join Date: Mar 2002
Re: i dont know where to post this ?
moved to the 7-72 message area for you.
#3 | |
Re: i dont know where to post this ? BUCKET SEATS
http://www.autoblueprint.com/1971_pa..._photopg1.html It's like 7 pages...but it chronicles the interior change I did to my 71 C-10 using Wiseguy's bucket seats. Hope this helps. |
![]() Join Date: Feb 2001
Re: Question on a 1970 GMC Buckets Seats Install?
I changed your heading to help you out...
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 05-08-2011 at 05:28 PM. |
![]() Join Date: Jul 2009
Re: Question on a 1970 GMC Buckets SSeats Install?
what brackets could i buy that would really close 2 mounting
The brackets are on the seat, just drill new holes and plug the old ones. The seats just bolt in, it is real easy.
Redefining LowBudget
Morning Mike
I put BMW buckets in my truck and wanted them low ..I stripped them down to the tracks cut a piece of 1/4"x2" flat stock...fitted the plates to the stock holes in the floor, just lay them over the factory holes with some weight on top then went under the truck with a sharpie and poked though the holes to mark the plates...my plates go across the truck...drilled out the holes and dropped in a bolt in each corner...placed the seat in the truck and sat in them to find a comfy placement that allows track movement front to back..marked the holes on the plate..took everything out drilled the plates for the seat and bolt them onto the seat..throw the hole thing back in the truck and bolt back into the factory holes.... It was easy and this way there is no fussing with extra holes or plating new bolt holes,Plus if I ever want to put the stock seat back in it will take 10 min or for that matter any other seat
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#9 | |
