Old 03-27-2003, 06:05 PM   #1
Tom
driving is in my blood
Tom's Avatar
turn signal wont blink?
Guys, my turn signals stoped working [correctly] yesterday. Sure they come on, but they dont blink. It just looks like I only have one brake light on. The light in the cab indicatiing the turn signal just stays on also, no blinking. What exactly do I need to replace, and what does it entail?
Old 03-27-2003, 06:17 PM   #2
Mike76251
If you have a bulb out then that will stop it from blinking.
It is designed that way to let you know you have a bulb out.
You have two wires that make the whole circuit and if any of the wires "break" then you know you have a problem. The filaments in the bulbs themselves act as part of these wires.
Change out your bad bulb and that should fix it.
Mike76251 is offline   Reply With Quote
Old 03-27-2003, 06:19 PM   #3
ironwood
$640 truck// doesn't run
You will most likely have to replace the flasher canister. Or what ever you call it.....It will be located on the fuse block (there will be two of them one for turn signals and one for emergency flashers..)
The smaller one will most likely be the one you will have to replace. The bigger one will be the emergency flashers and it is a heavy duty unit, you will want to flip flop these units to see if it actually is the flasher unit before you go buy one... I don't think they are that much though $4??? The blinkers, if it was the flasher will blink faster than normal just because the heavy duty unit will be in operation.. That should tell you if you need one or not if you do buy one change it out and hopefully that will do it ...
Good luck
Dave
PS buy a standard unit or your blinkers will flash like crazy like when you tested it.
74 C-20 LWB
camper special
stock350/350
53 Chevy 1/2 ton- in California, where the rust is not. Ready for some LOVE!!!
ironwood is offline   Reply With Quote
Old 03-27-2003, 06:22 PM   #4
ironwood
Try Mike76251's idea first then if that doesn't work try mine...
But didn't you say that your light was staying on like a brake light? That would mean the bulb was good, does it not?
Dave
74 C-20 LWB
camper special
stock350/350
Old 03-27-2003, 06:24 PM   #5
Tom
Tom's Avatar
sweet, dont have to take the steering colume apart. I know the bulbs are ok, cause when I put the truck in park, hit either of the flashers, go back and look the side Im trying to get a turn signal on will just be lit up, but no flashing on and off. Thanks guys
Old 03-27-2003, 06:33 PM   #6
Mike76251
Re: turn signal wont blink?
I disgress,
That post line got me thinking that it is a bulb,
Sorry.
Put a new flasher in there and let us know.
It just plugs into the fuse block and is a piece of cake.
Old 03-27-2003, 09:54 PM   #7
Tom
Tom's Avatar
It was the turn signal fuse. Thanks guys!
Old 03-28-2003, 01:07 AM   #8
ironwood
Anytime, glad to see I can help the fellow blind.
74 C-20 LWB
camper special
stock350/350
