Old 05-08-2011, 06:10 PM   #1
JGross
Anyone else have this problem with their window weateherstriping?
I got new window weatherstriping from LMC and installed it the proper way (I think), with the window all the way up there's still a small gap between the window and the weather striping. The gap is the same on both the drives and passengers side. Anyone else have this problem? the PO had already removed the old weatherstriping so I can't tell if the new went in the same way as the old.
JGross is offline   Reply With Quote
Old 05-08-2011, 09:13 PM   #2
PGSigns
PGSigns's Avatar
Re: Anyone else have this problem with their window weateherstriping?
Is the window up tight in the front? The tracks may be mis aligned.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-08-2011, 09:50 PM   #3
gulffishin
gulffishin's Avatar
If I had to guess, I would say the fuzzie pieces in the door are keeping your window from going all the way to the top. Mine do the same thing... You may not like my solution, but what I do is pry them away from the window little while rolling them up.
gulffishin is offline   Reply With Quote
Old 05-08-2011, 10:31 PM   #4
'63GENIII
'63GENIII's Avatar
X2...Sux!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 05-09-2011, 12:03 AM   #5
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I experienced the same problem last night. My window went up a little more than yous did, but the window track was hitting the outer belt weatherstrip (fuzzy). Once I pulled out a little it rolled right up. I figured it was my repop doors. I think it will work itself in because it was barely hitting. It was just enough to catch.
I operated the window after each piece I installed to make sure it would work fine.
The one thing I don't like the most is the window track is slightly visible once it is rolled up. Most people will not notice it.
Alan's Classic is offline   Reply With Quote
Old 05-09-2011, 12:14 AM   #6
66 lwb cs
66 lwb cs's Avatar
^^^^ Your truck looks bad a$$ anymore pics not trying to thread jack sorry about your window problem maybe talk to a tint shop or window shop sometimes in the past with another type of vehicle I had which shall remain nameless the windows would get a little tacky from use and a good cleaning would help them slide better perhaps there's a product the 2 entities I mentioned would know of that also acts to lubricate the affair. Good luck.
66 C20 LWB CS 327/TH400 A/C
66 lwb cs is offline   Reply With Quote
Old 05-10-2011, 01:16 AM   #7
PAPA KENT
PAPA KENT's Avatar
yes when i installed the new fuzzies i had the same problem in my stock doors,the originals are much thinner so i am going to see if i can lightly take a small grinder to them and see if that works.good luck!
PAPA KENT is offline   Reply With Quote
