Old 05-09-2011, 09:42 PM   #1
bark
mounting computer in cab????
I was wondering if its OK to mount a computer above the heater box in my 76, will it be to hot sitting there, is there a reason they are mounted outside the cab from factory??
bark is offline   Reply With Quote
Old 05-09-2011, 10:02 PM   #2
ls1nova71
ls1nova71's Avatar
Re: mounting computer in cab????
You can mount it there, it shouldn't be any hotter than the engine compartment in the summer.
I think the factory mounts them under the hood just for convenience. The hardest part about mounting it inside the cab is getting the wiring harness through the firewall, it takes a good size hole, then you need to figure out how to seal it up when your done.
ls1nova71 is offline   Reply With Quote
Old 05-09-2011, 11:37 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I kept mine underhood, but in front towards the venting in the core support/inner fender. I was hoping that might keep it a bit cooler, and I had space there. There isn't a ton of room under the dash, especially if you have a good amount of after market wiring or things like stereos etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-10-2011, 01:20 AM   #4
72mike
Here's mine in that same spot.
72mike is offline   Reply With Quote
Old 05-10-2011, 05:54 AM   #5
67C10BUB
67C10BUB's Avatar
I put mine under the hood using the factory mount.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 05-10-2011, 10:53 AM   #6
Clyde65
Clyde65's Avatar
Me too!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-10-2011, 10:50 PM   #7
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Mine is under the hood, might get moved in the future. What stopped me from going under the dash was not knowing where I would have space when I get aftermarket AC.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-11-2011, 02:13 AM   #8
matthew20061
69' Chevy Stepside
matthew20061's Avatar
I've got a custom center console so I mounted mine inside of that and the harness comes up though a hole in the transmission tunnel. Seems to work good and its sealed with a rubber boot.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 05-11-2011, 07:22 AM   #9
79bonanza
yea when i do my swap ill have to find somewhere good and dry and safe from the elements of trail riding and wheelin so any good pics of in cab mounts would be good
79bonanza is offline   Reply With Quote
