![]() Join Date: Aug 2004
LSx Tach output? 4Cyl or 8?
I cant remember what it is and am putting a tach in soon.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: LSx Tach output? 4Cyl or 8?
I used the 4cyl configuration on my tach.
yours is wired right from the PCM?
Yup. Speartech reworked the harness for me. I recall reading on a forum, it may be necessary to add a take up resistor. I did not and everything works correctly.
Has more rust than truck...
It can be changed in your tune, so a call to your tunner may be in order. If it dosent work, TR65's resistor pull up thread is in the FAQ.
Thanks guys!
If you're using a factory tach that is not adjustable for 4, 6, or 8 cylinder applications, then you'll need to have the 'tach resolution' changed in the tune from 6 to 3. (for an 8 cylinder tach) If you're using an adjustable aftermarket tach, then just set it for 4 cylinder.
Ok, Cool, Thanks Ls1nova71.
