Ls fuel pump ???
I have a few questions about what in-tank fuel pump to run for a 08 5.3l. This is going in a 85 pickup. I did a search and found that alot of guys are running the AC Delco Ep 381 pump. I've been told that this pump was not designed to run at 58-60 PSI. And that it would not hold up for very long. I've also been told that it well work just fine and that it well flow 50-60 GPH at 70 PSI running 15 amps. Is this true? This going to be DD with 60 miles aday round trip. Thanks in advance
Re: Ls fuel pump ???
It may be possible to adapt the 08 fuel pump module into the 85 gas tank. That way no need to wonder. I actually did that with my 66 C10 when I relocated the tank to the bed.
![]() Join Date: Aug 2004
Walbro 255 pump. perfect for intank or external.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Thanks for the info guys. raic65. I'm going to be doing the blazer tank swap also. I was thinking of looking in to the ls truck senging unit -pump set up also. But didn't think it would fit the tank. I was going to see if Auto zone could get the new assm. and then just take the lock ring for the blazer tank in w/ me to see if thay are the same size. I didn't want to post that quetiuon thinking everyone is go to think this guy is NUTS.
BAD BOW-Silverado XST
Read this article on a conversion and intake fuel pumps.
http://www.hotrodlane.cc/77chevytruck/77chevy.htm |
BMW & ASE Master Certified
ive had the same EP 241 (application used was for an 85 corvette) and used it for 70mi round trips for 8months and then the commute went down to 40mi... drove it from houston to florida 1800 miles and back with 0 problems. Stock engine with bolt ons. I bought a second one for the driver side fuel tank and never installed it in the tank.. just looking at me evertime i go into the garage.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
