Old 05-11-2011, 06:56 PM   #1
cfan10
cfan10's Avatar
truck won't start :(
What is wrong with my truck, it won't start battery is good. Makes clicking noise when I hit key. Any advice could it be the starter? Thanks.
cfan10 is offline   Reply With Quote
Old 05-11-2011, 07:23 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: truck won't start :(
First I would check an make sure all the connections on the battery cables are making good contact.
Will it start if you jump it with another vehicle.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-12-2011, 11:00 AM   #3
Keith Seymore
Keith Seymore's Avatar
How do you know the battery is good?
Can you put a battery charger on it to verify? (or jump it, as previously mentioned)?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-12-2011, 12:24 PM   #4
Eyegore
What Hump?
Eyegore's Avatar
I learned this from a mechanic:
Set parking brake!!!!!!!!!!!!!!!!
Have someone get in the truck, then in in park or netrual, have them turn the key as to start, then you, under the truck lightly (lightly) tap the starter with a small hamer, if it engauges replace the starter solenoid or the whole starter. If it does nothing then you may have cabeling, ignition and or battery problems.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
