05-12-2011, 05:11 PM | #1 |
ideas for shop
May be buying a house that is being built. It will have a shop on it. Any suggestions for this shop that will help with our hobby? Mostly what kind of electrial to put in,fans, lighting,anything.
05-12-2011, 05:23 PM | #2 |
Re: ideas for shop
Try the garage journal forum....there are lots of ideas there.
http://www.garagejournal.com/forum/index.php? |
05-12-2011, 06:15 PM | #3 | |
Re: ideas for shop
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
05-12-2011, 07:25 PM | #4 |
Re: ideas for shop
Having just bought a new construction house 1 1/2 years ago here are my suggestions:
minimum of 24' deep. 30' deep if you hope to pull an engine with the door closed. electrical sub panel in the garage so you can easily add 220 circuits later as many outlets as you can get away with, on dedicated circuits not shared with other rooms in the house gas line for a heater insulation for heating and cooling, walls and ceiling flat floor, not sloped if you do any chassis fabrication type stuff hi-lift garage doors so the doors hug the ceiling instead of hanging down
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
05-12-2011, 07:40 PM | #5 |
Re: ideas for shop
High ceiling so you can lift rigs up, pull engines, or even install a lift someday. Also gives you storage up high for larger pieces. I wish I had plumbed a sink in mine, wife is always on me about the "garage smells" I bring in on my hands and greasy door knobs. I built mine with a stair to the attic using attic trusses with 250# psf floor loading, I assumed correctly that I might be storing heavy stuff up there one day. Lots of blocking for shelving, supports. Make sure you have at least two outlet circuits, one switched and one hot all the time. I staggered mine and have the stero, portable lights, and one light plugged in to them so when I leave I don't leave the lights burning. Wire the main lights separately. Size for 3 220v separate circuits, welder, compressor and a/c or future big draw tool.
05-14-2011, 05:44 PM | #6 | |
Re: ideas for shop
It will just double everything except the cost, and that will triple !!
05-14-2011, 11:39 PM | #7 |
Hollister Road Co.
Re: ideas for shop
on more than one occasion I have wished I had floor anchors so I could chain down a frame or front end.
05-15-2011, 01:54 AM | #8 | |
Re: ideas for shop
We are actually seeing how much trouble it would be to add pods into the floor. if you need to poor a floor??? Put Pods In..!!!
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
05-12-2011, 07:35 PM | #9 |
Re: ideas for shop
how big? tons of ideas, but at what cost? what are you gonna do in it? metal fab,? paint?
would a mid rise lift be considered an appliance? best money I ever spent..electrical is easy.... 220 for welders and compressors, although I only use a small mig that runs on 20 amp 110.. LOTS of light !!! wire it for a lot of t8 fluorescents. i think i have like 40 in a 30 x 40 shop , that includes 8 for the walls in the paint room. nice sloping floor drains..in a wash or paint area, but flat in a fab area !!. a heater.... exhaust fans (louvered) built in. like I said, we all have tons of ideas, but answer the above questions! Last edited by skip99; 05-12-2011 at 07:36 PM. |
05-12-2011, 08:48 PM | #10 |
Re: ideas for shop
Believe it will be a 24' x 30'. I like the ideas, did not know there was a garage forum. I will check it out. I may be buying the house and the builders don't budge on the price but will put in extras so I need to make a list.
05-12-2011, 09:53 PM | #11 |
Old Heap Driver
Re: ideas for shop
Everything mentioned above and..............
Lights Lights Lights and Outlets Outlets Outlets! Wiring for a couple ceiling fans. Maybe an I-beam you could attach a winch or chain hoist to. And of course, wiring for cable, phone, and internet.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
05-13-2011, 12:56 AM | #12 |
Re: ideas for shop
Here is a pic of mine. S-10 reminded me I also had two of the trusses 6' in from each end designed to support 2000# so I could use them for lifting which I have.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 05-13-2011 at 12:58 AM. |
05-13-2011, 08:32 PM | #13 |
Re: ideas for shop
radiant floor heat for sure...
05-13-2011, 11:26 PM | #14 |
Re: ideas for shop
I did a 40x40 metal building with 15 foot walls insulated. I would do roll up doors front and back so that when it is hot you can get air to circulate through it unless you go with vents with fans built in. On my electrical I have 6 8 foot florescents on the celing. 220 outlets on every wall. 2-3 110 outlets on every wall. Dedicated wiring for the compressor. I did a 110 amp disconnect from the house for mine. I would run tv, phone, and internet if you dont have wireless.
put in extra stobs for electrical and water when you do the forms. I wish I would have put in more than i did with everything i ended up putting in my shop. |
05-15-2011, 12:52 PM | #15 |
Re: ideas for shop
Heres a link to a little something i've been throwing together.
http://www.garagejournal.com/forum/s...ad.php?t=97652
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
05-15-2011, 02:26 PM | #16 | |
Re: ideas for shop
Oh, and I used 'U-Coat It' epoxy floor coating and (if your thinking of that) would recommend you use a dark color (I used light grey and it is not as stain resistant as they say)...Also, buy more than they recommend. Last edited by vjjack04; 05-15-2011 at 02:30 PM. |
05-15-2011, 05:49 PM | #17 |
Re: ideas for shop
We don't all have it, but the best thing to have is a 40 x 60 or larger all metal shop with 14 foot inside height, and the steel rails or I beams in the floor is a good idea, as somthing to weld stuff to to pull against etc. A little attached house garage is not the way to go. And not safe either. I think they should have been outlawed years ago, all houses should have detached garages.
05-15-2011, 06:38 PM | #18 |
Re: ideas for shop
I recommend plumbing for at least a toilet. A shower would also be nice but maybe not worth the sacrifice of floor space. I hate running into the house just to take a leak, especially in winter.
58 Apache short fleetside ona 64 chassis: |
05-15-2011, 07:09 PM | #19 |
Re: ideas for shop
This is great, this is what I wanted "those, I wish I would have", "word from the wise", ideas. I am gathering the suggestions for my list. Thank you.
05-15-2011, 07:50 PM | #20 |
Re: ideas for shop
one of my "wish I woulda done" is put 2, 220 volt plugins in the same area that you designate the metal fab area. I get tired of unplging the welder so I can plug in the plasma cutter. another idea i did do & glad I did. Put a 220 plugin close to the big door, so you can reach outside & weld on stuff you cant get into the building.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
05-15-2011, 08:32 PM | #21 |
Hollister Road Co.
Re: ideas for shop
one other thing I would like is a jib crane. It would be very useful for what I do.
I have the 220 in two locations and it's used a quite often. Mine isn't near the door but I wish it was. Last edited by dwcsr; 05-15-2011 at 08:37 PM. |
05-31-2011, 08:19 AM | #22 | |
Re: ideas for shop
What deminisions is the arm, and height, considering the building height
05-31-2011, 10:48 AM | #23 |
Re: ideas for shop
There's a guy a few houses down from me. He's building a huge 3 stall garage/shop in his backyard. I walk by his house daily to pick up my mail. They've been building for about 3 months now. I finally talked to him last week, and he gave me a tour. There's (2) bendPak lifts in 2 of the stalls, (4) 220 outlets. A/C, Heat, great lighting. I asked him what he's planning on building. His reply was nothing. He said having a shop makes changing the oil in his truck & wife's car easier. I know he's not a car guy. We talked about my 53 & 59 about a year ago. He just couldn't understand why people would still drive such old vehicles.
05-31-2011, 11:16 AM | #24 |
Re: ideas for shop
OH Boy, with that kind of expense he could almost buy a Jiffy Lube and change his oil once a week!!
05-15-2011, 09:35 PM | #25 |
optomistic ah-so
Re: ideas for shop
For San Jose I'd make sure that AC goes in during construction...in California getting permission to add it later (especially if an HOA is involved) will be a nightmare. Beyond that, everyone's already said most of the best ideas.
Even though you will not be painting whole cars in the shop, you'll catch yourself painting parts--think about filters and ventilation. A hood where your worktable will be should do fine for that as well as for any fumes that may arise during welding and cleaning.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
