Power Brakes and Original Drums?
Hello Everyone,
Anyone know if you can add power brakes to a 67 with a I6 and a 3 on the tree tranny? Would like to do something that I can handle (newbie). Any pics of your setups would be appreciated. Also if anyone has suggestions on how to best do this I would also appreciate it. Thanks David |
![]() Join Date: Mar 2000
Re: Power Brakes and Original Drums?
Really easy. Most of the half or 3/4 ton boosters should work. Just make sure that the push rod from the booster to the master cylinder is the correct length. You can make the 73-87 boosters work pretty easy too but you will have to do a small amount of modification to it to make it work. If you happen come out this way I'll give you a 73-87 that's already modified. I have some 67-72 models as well but the price wouldn't be quite as good LOL. Scott's Super Trucks in Penhold probably has used stuff around or will be able to hook you up with somebody that does.
Saskatoon, Saskatchewan Canada Last edited by StingRay; 05-13-2011 at 10:54 AM. |
I'm getting ready to do this swap myself. Already have a new booster, just trying to find the time to do it. Ditto on the booster push rod to master cylinder length. My booster has really short push rod, and my master cylinder uses a longer push rod. I'm gonna have to create a filler/extension to compensate for the deep hole in the master cylinder and the short push rod on the booster. I have read that you don't have to disconnect any of the lines to the master cylinder to install the booster, just unbolt MC from firewall carefully push it forward, bolt on booster, then attach MC to booster. Here's a good link on how to install...
http://67-72chevytrucks.com/vboard/s...d.php?t=221598
![]() ![]() ![]() 1970 Chevy C10 LWB 307 3OTT 3.73 gear |
#4 | |
Thanks for the info. David |
Was wondering if your offer for a brake booster still stands? If you can pack it up and send it via greyhound I would pay for the shipping. Let me know StingRay.
Thanks for the help. |
![]() Join Date: Jun 2005
That is correct, just unbolt the master with the lines intact and CAREFULLY pull it forward. Also you may need the linkage rod that goes to the brake pedal unless yours is adjustable.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
the boat guy
I blew apart a stock drum without power, going down the highway. Make sure everything else is in good working order. I am running disc now.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
If you have all the parts, it is a quick hour or less job.
Best mod I did to mine.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
I am a Referee of life.
Just so you know,this is a snowball job.The booster works fine but there isn't room for a stockk air filter assembly.You will either need a factory offset one or aftermarket.I suggest the aftermarket to start with so you can drive it while you find and offset one if you want a stock set-up.There should be a port(plugged) under the carb that will work for vac.I got the fitting at the LPS.If you change the booster rod and need to unbolt the rod end from the pedal,you will either have to drop the column or remove the spring(before mounting the booster) so the pedal will swing down to acess that bolt.(It's a shoulder bolt).
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
If you use this booster:
![]() And this air cleaner: ![]() They fit! I just don't have a picture of the two of them together.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
Here-I took this today:
![]() Not a very good close-up: ![]() There is a-dimple-(for lack of a better word) on the bottom of the air cleaner. It clears by a good quarter inch.
