Old 05-14-2011, 12:09 AM   #1
PugDad
PugDad's Avatar
1977 Heavy Half, what weight trailer can I tow?
The data decal on the door is pretty much unreadable.
I want to buy a travel trailer. How do I figure out what weight trailer I can pull?
PugDad is offline   Reply With Quote
Old 05-14-2011, 07:31 AM   #2
James McClure
One shot, one kill.
Re: 1977 Heavy Half, what weight trailer can I tow?
10,000 pounds with a good reciever type hitch, about half that with a bumper hitch. Either way toung weight will be about 500 to 800 pounds. I don't have a clue what a gooseneck will do, but I imagine it's up there, 15 or 20,000?? jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 05-14-2011, 09:52 AM   #3
PugDad
PugDad's Avatar
Thank you, sir!
Old 05-14-2011, 01:54 PM   #4
C-10 simplex
Which model do you have?
C-10 simplex is offline   Reply With Quote
Old 05-14-2011, 02:36 PM   #5
big10ratrod77
big10ratrod77's Avatar
you realy cant over load a big 10, but you can improperly load one you also wanna check your brakes, shocks ect. before you try to haul that much
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 05-14-2011, 03:16 PM   #6
PugDad
PugDad's Avatar
The fender emblem says Cheyenne 10, so I'm guessing a C-10
Old 05-14-2011, 06:01 PM   #7
Matt Man
Matt Man's Avatar
i wouldn't tow 10,000lbs with a half ton regardless if its a "heavy half" trying to stop is going to be your problem i would say 7,000 max.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-14-2011, 08:02 PM   #8
76stepsidechevy
my 76 says 6200 on the door tag, im fairly certain thats the number that makes it a big 10 but I could be wrong.
76stepsidechevy is offline   Reply With Quote
Old 05-14-2011, 09:08 PM   #9
PugDad
PugDad's Avatar
Well, I know the vin designates mine as the heavy half. So, if yours is 6200, mine probably is, too.
Old 05-14-2011, 09:34 PM   #10
Keith Seymore
Keith Seymore's Avatar
I towed with this setup for years and years; approx 4500 lbs counting the car and trailer.
My truck is a V6, manual, regular half ton - so you shouldn't have any problem with 4000 - 5000 lbs.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-14-2011, 09:42 PM   #11
PugDad
PugDad's Avatar
K
Thanks, Keith.
Old 05-14-2011, 10:53 PM   #12
C-10 simplex
Which engine you got?
Old 05-15-2011, 01:23 AM   #13
PugDad
PugDad's Avatar
Looks like a 350
Old 05-15-2011, 09:43 AM   #14
Goldfinger
Goldfinger's Avatar
my 85 c10 with hd suspension from the factory can tow 12 on the bumper with about 1/2 ton of tongue weight. with a goose-neck you can tow much more as long as your brakes and wheels can support it. Remember any more than about 4 tons, its towing you
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 05-15-2011, 12:00 PM   #15
C-10 simplex
If it's a 350, then the GVWR is 6200lbs. Not sure what the GCWR is.
But the other thing you can do just to be safe is to go to any chevy dealer's parts counter (could be any GM dealer, but probably best to go to a chevy dealer), give them the vin# and they can look up all the pertinent info on the computer----GVWR, GCWR, rear gear ratio etc. etc.
Old 05-15-2011, 12:14 PM   #16
PugDad
PugDad's Avatar
I just found 1977 Chevy build records. It confirms what you just said, 6200 lbs.
Fourth digit in VIN is a 4, which as my understanding is the heavy half designator.
Also, seems to be the 68th unit to roll off the line in Fremont. Where the heck is Fremont?
Old 05-16-2011, 01:21 PM   #17
Keith Seymore
Californ-i-A.
So the sequence portion of the VIN is 100068-ish?
Be advised trucks weren't necessarily built in VIN order (close, but not quite).
K
1979-1986
1986 - 2019
Old 05-16-2011, 02:03 PM   #18
Pop's C-10
Pop's C-10's Avatar
check tha vin in tha motor to see what you realy have
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 05-16-2011, 02:45 PM   #19
PugDad
PugDad's Avatar
That will be no good...it has a Goodwrench replacment motor in it.
Old 05-17-2011, 01:31 AM   #20
DetroitDan
DetroitDan's Avatar
Please don't tow 5 or 6 tons behind a half ton truck. Just because people say they have done it doesn't make it safe, legal, or smart.
You have small wheel studs (and less of them). You have little tiny load carrying bearings and you don't have a full floating rear axle. A heavy half might have a bunch of springs in the back, but it does not have adequate cooling to tow 10k, it does not have enough brakes (regardless of trailer brakes), and unless you upgrade your wheels and tires aren't up to it either.
A trailer is on wheels, so of course you can pull on it and cause it to move. But there is far more than that to safe, responsible trailer towing.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 05-17-2011, 02:09 AM   #21
PugDad
PugDad's Avatar
No worries...I'm looking at small to mid-size trailers. I'm also concerned about length, I don't want to tow over about 17-20 ft, and the ones I've seen are about in the 3000-4000 lb range. I started asking the question because the body tag is not readable, but I have since found out what the GVWR is. But, I do appreciate your advice...good way to break it down. Thanks.
Old 05-17-2011, 06:16 AM   #22
Altec
Getcha Pull
Altec's Avatar
Already been covered, but I figured I'd post this information for anyone who finds this thread in a search.
Lowest Rated C10 = 4900lb (With Nothing...)
Highest Rated C10 = 6200lb (With V8)
Lowest Rated C20 = 6400lb (Standard/Regular Cab)
Highest Rated C20 = 8200lb (Heavy Springs/Crew Cab)
Lowest Rated C30 = 6600lb (Standard/Regular Cab)
Highest Rated C30 = 10,000lb (Dually/HD Brakes)
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 05-17-2011, 01:32 PM   #23
C-10 simplex
i've always wondered what was the purpose of this; i have the "heavy duty" springs on my 1/2 ton, but i have 2.56 rear, stock brakes, no aux trans cooler etc. Why bother? i can load the bed with 2000lbs of corn, but i still have to drive it to market.
As you probably know GCWR is different from GVWR.
We need to find out what GCWR is on the truck. i'm not sure where to find it. Do you have your owner's manual handy?
4000lbs trailer with 1000lbs in the bed is actually kind of pushing it for a 1/2 ton, but let's do more research.
P.S. GVWR= Gross vehicle weight rating. How much total can the truck itself, fuel, driver/passengers and load weigh.
GCWR= Gross combination weight rating. How much totally can the truck(including above mentioned load) plus the trailer weight.
Or something like that. There is probably a good link that describes all that, but i don't have time to find one.
Old 05-17-2011, 03:20 PM   #24
PugDad
PugDad's Avatar
No info in the owners manual
Old 05-17-2011, 03:29 PM   #25
Keith Seymore
Marketing.
It allows the Chevy marketing guys to brag about how much more their truck can haul over the Ford marketing guys.
That is, until the Ford marketing guys figure out how to raise the bar and then change their advertising....
K
1979-1986
1986 - 2019
