just finished my front crossmember section
here are some pics, 1.5"
Re: just finished my front crossmember section
wow! cleanest one i'v ever seen. awesome welds
That looks really good. Nice work.
68 Chevy C-10. swb fleetside. 6.0 4L80E swap. http://67-72chevytrucks.com/vboard/s...d.php?t=460877 |
Square
pretty awesome man!
Squarebody Syndicate |
Chevy Only Tx
Good looking welds!!! Let's see what kinda truck it's going on
Chevy Only Tx......... |
Wow........I agree Looks Great. I might be wrong, I dont know everything but that looks like alot of work for only 1 1/2 inch lower. whats the Gain? Im open to learning more..
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
In my opinion its either section the crossmember or do a Z in the chassis, i think this is an easier option to gain 1.5".
This was my last choice before spending lots of money on a aftermarket crossmember, i will allways choose self build over purchased items, thatway i gain more knoledge, Last edited by roofingbloke; 05-16-2011 at 01:35 AM. |
combined with a z of 3.5 this will net you 5 inches of drop. also depending on which body it is a z is required, i think in order to lay a square body on its frame in order to clear lower control arms. but to lay the pinch it will need a stock floor body drop or some kind of body drop to lay any kind of body
[B]I agree with your "[i will always choose self build over purchased items, that way i gain more knowledge," comment.
To me that might be one of the smarter comments I have seen here. Buying is not building. that's why the Ol' Skool Chevy Name..I build the way we did in the Old days Nothing new. I guess my only thinking on your cross member was "what's the gain" but if your going seriously low I guess anyplace you gain ground clearance is a plus. Again GREAT WORLK............... /B]
Great job!
Wow, I wish I could weld like that!
----------------------------------------- My 67 c10 Thread. http://67-72chevytrucks.com/vboard/s...d.php?t=409192 |
Square
The 1.5 out of the cross member is still going to put the control arms and cross member on the ground. But it will help the truck sit a little more evenly when laid out. On my truck the crossmember needed a lot more work than a pancake to lay pinch.
This is with 2" out of mine with 2.5" drop spindles. (and temporary motorcycle springs that let is sit another 2" lower)
28.5" tall tires. ![]() |
[QUOTE=Scot_Douglas;4684271]This is with 2" out of mine with 2.5" drop spindles. (and temporary motorcycle springs that let is sit another 2" lower)
28.5" tall tires. ![]() wheres your tie rod????????
#15 |
#16 |
#17 | |
Sorry for the thread hijack, Bloke! |
#18 |
It'd be alot cooler if you did
I'm more interested in whats going on out back, I've seen a rack and pinion before.
#19 |
#20 | |||
![]() Here's a good shot showing the stock motormounts in place: ![]() Quote:
#21 |
I see now at that angle. No tie rod, you used rack...nice
#22 |
Nope, nothing is wrong , that's what happens when you go 1.5".
Posted via Mobile Device |
#23 |
Yep. The possible steering related issues are mentioned in most (if not all) of the notched/pancaked/sectioned x-member threads. Hard to miss....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-19-2011 at 07:23 PM. |
#24 | |
Oh well, tape measure out again, my options are, move my steering up the same 1.5" or go rack and pinion, Thanks for the replys. |
#25 |
On the fast track to nowhere..
Mine required some grinding at 1.25" so I can imagine you'll need some at 1.5".
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
