Old 05-18-2011, 04:11 AM   #1
daRookie
6.0 vortec 72blazer 350 trans 205 tc
Hello everyone i have a couple questions..
a friend is selling me a 6.0L Vortec engine and i was wondering if i can swap out my 350 engine i currently have on my 72 blazer.
he is including the wiring harness but before i purchase the engine i want to know what i need to be able to install it in my 72 blazer.
my blazer currently has the original 350 engine and 350 trans with a 205 transfer case. dana 44. if anyone can help please contact me at ibarra_elec@yahoo.com
daRookie is offline   Reply With Quote
Old 05-18-2011, 09:27 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 6.0 vortec 72blazer 350 trans 205 tc
To the site! I'll be moving this post to the LSx section where you will find all the info you need. Be sure to check out the LSx FAQ at the top of the section or there is a link to it in my signature.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-18-2011, 11:57 AM   #3
Super73
Super73's Avatar
The good thing is you can use your factory trans / t-case. I don't know what a TH350 converter bolt pattern looks like compared to the one coming with the motor (if there is one) but Hughes as well as several other companies make adapter flexplate that have the Gen3/4 crank shaft bolt pattern and the older style converter bolt pattern on it. http://www.summitracing.com/parts/HUP-HP4004X/
You will be able to get 5 of the bellhousing bolts bolted up to mate the old trans to the new motor. I have run an old 80E that way for 4+ years.
You have the option of staying carbed with Edelbrocks different kits but I wouldn't:
http://www.summitracing.com/parts/EDL-7118/
http://www.summitracing.com/parts/EDL-2908/
http://www.summitracing.com/parts/EDL-71181/
To run the factory fuel injection you are going to need a high pressure fuel pump and regulator. A lot of people run a factory C5 fuel pressure regulator because you can stick it anywhere in the line, it's cheap to buy and easy to source. The fuel pump, I personally prefer inline pumps like a walbro unit: http://www.summitracing.com/parts/VPN-GSL392/
So we have covered trans issues and fuel issues (and spark if you go with the edelbrock system), so let's talk spark for the factory set up. In all reality there are only a few things that need wired to run (if memory serves). Once these are hooked up, the factory PCM will control spark to the coil packs.:
Fuel pump relay (should be an output from the PCM for your relay)
Two ignition feeds to the PCM (key on ignition to the PCM, both red and blue need power, put the power through a relay)
Starter solenoid (Big purple wire in the factory harness)
Now, there should be a factory antitheft control device preprogramed in to the pcm and that will need to be removed or bypassed. Any local tuning shop or mail order guy could remove it for you.
You also should wire up the OBD2 port and wire in a service enging soon light so you know if there are any issues.
You also need to have two bungs welded in to your exhaust for the front Narrow Band O2 sensors, the rear two after cat ones can be disabled in the pcm when the tuner removes the anith theft system. While they are at it, you probably want them to remove most if not all smog related junk in the tune, set your gear/tire combo, things like that.
I might be forgetting something but that's the real basic deal. There is a lot more you can do, but that is entirely up to you.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
6.0 swap 350 blazer
