![]() Join Date: May 2011
3800 Supercharged V6 in C10?
My parents have a '98 Park Ave Ultra with the supercharged 3.8. The car only has 100,000 miles on it and runs superb. The body however, is starting to fall apart. They've owned it since '99 so its time for a new car... I may be able to get it for little/nothing.
I have read that it is possible to use the tranny from a late '90's Camaro as it will bolt right up. the 350 in my truck is very tired, and it would be a fun project for the winter. Ive seen 30 MPG in that Buick on the highway, and it goes pretty good with the 240 HP V6... Anybody here done this swap or know of anybody that has? |
Re: 3800 Supercharged V6 in C10?
Sounds like a cool swap though! That may just be because I know where there is one of those engines also... ;-)
Posted via Mobile Device |
![]() Join Date: Mar 2005
Are those cars front wheel drive?
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
![]() Join Date: Nov 2008
Yes that should be a FWD car ... I had a 97 Pontiac GTP , car scooted very nicely with the Supercharged V/6 .... It would probably be more fun in a S-10 , alot lighter . Just my 2 cents
![]() Join Date: Aug 2004
Are the Buicks FWD or RWD?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I have car A.D.D.
They are a front drive car. But the original post states that he may be able to bolt the motor to a Camaro transmission. Which would then make a drivetrain that is rear drive. It would be different for sure. If you do it, do the intake gaskets while it is out. You dont want to do them in the truck. A lot more work.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
Intake gaskets are a must if you do the swap and you should be able to find a tranny out of a camaro that will bolt too it. Be ready to do some fab on motor/tranny mounts, exhaust. Keep us posted if you do it.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
![]() Join Date: Jul 2010
It will work with a f-body trans...jus do think get 30 mpg when it in tha truck..And they make a boat load of hop up parts..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
I am looking for one of the new camaro v6's with a 6 spd auto 300hp 29mpg now that is cool..
Yes, it will bolt up to a camaro trans. I have an engine out of a 06 grand prix in my '97 firebird. The 3800 in the camaro/firebird is the same in long block form as the FWD ones. The only differences are the intake/exhaust mainfolds and sheetmetal. They even use most of the same sensors. Try to find a set of the engine side motor mounts from a camaro/bird, they will be easier to work with in RWD mounting than the FWD mounts.
These are good engines and it should last you another 100k if its been maintained correctly.... edit: I forgot the heads on the SC versions are different. They have the mounting bosses for the fuel injectors in the head instead of the intake because of the supercharger. They also have a sligthly lower compression ratio (I think)
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 05-20-2011 at 01:54 AM. |
![]() Join Date: May 2007
this is a great idea, if you need any help with wiring I would be glad to support this swap.
Not to burst anyones bubble, but I think you may have trouble with the motor mounts, being they were for a fwd car.
If you want to go with a modern motor, I would go with a 5.3 LS truck motor. They make good hp and torque, and get good fuel mileage. Also its made for a truck. Just my opinion. And for side note; Im know you can use a old th350/400 or old school manual for the LS motors.
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet Last edited by NCD1966; 05-20-2011 at 11:34 AM. |
#13 | |
:bubblesnotburst: |
fan of "Butters" Stotch
I kind of like the idea. It would be worth a shot if you want to be different, especially with everyone (including myself) doing a LS swap.
I'd try to find everything out of a V6 camaro; manifolds, tranny, flexplate, starter, ect.
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() |
#15 | |
Also all the series 2 and series 3 engines are the same. The difference is a series 3 has a little bit better/stronger connecting rod and a slightly larger exhaust valve. I've done all the reasearch on this since I put a 06 series 3 in my firebird that had a 97 series 2.....
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#16 |
I was wondering about the accessories on the front of these; its nice to know the FWD stuff works.
Are pulley swaps & blower porting commonly done on these?
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() Last edited by tapeworm; 05-21-2011 at 09:04 AM. |
#17 |
yes...but there are other mods that need to be done before you start droping pully sizes...google tha term top swap
#18 |
McMullin
What sort of fuel mileage numbers do you think a v6, 5 speed manual, and high ratio rear would achieve?
#19 |
The fwd accessories won't work in an f-body, but they should not cause a problem in this style truck. They won't work in the f cars cause the layout is all wrong.
The V6 f cars are 10 lbs of stuff in a 5 lbs bag. The V8 is 15 lbs, lol. Intake gaskets are a common problem. I don't think they would be too hard to do in the truck engine bay. I'm not as familiar with the s/c specific questions. A good place for that info would be club gp. Don't expect to get another 100 HP with a pulley swap. These engines are not intercooled.... Posted via Mobile Device
#20 |
takin notes if it works my next project is my 52/s10/park ave. motor
Im stright up ESL student........ ![]() 94 s10 4x4 4.3/5speed (dd) 68 lwb GMC 350/4speed 52 5 window GMC I6/4speed 12v (8lugs and long bed) 53 bel air 235 I6/powerglide |
#21 |
The Buick 3800 was always one of GM's best engines I could never figure out why GM did not use it more often. It would have made the S-10, Fiero and lots of other cars more fun. The 2.8 & 3.1 engines were just terrible.
The 3800 was also used in the Buick GNX, I had the the early version (231 cu in) as the stock factory engine in my 71 CJ-5. IIRC the GNX was available as normal aspiration, turbo & supercharged with standard rear drive configuration. Those parts may be rare but they are out there. Not sure if any aftermarket manifolds or other parts are available. Good Luck with the build!! |
#22 |
Sorry, I meant to say I had the stock, normal aspiration version in my 71 CJ-5. I did not have a supercharged Jeep, but that could be a really fun ride.
#23 |
The earlier series 1 3800 like your talking is a very different animal. It won't interchange with a series 2 or 3. Lots of internal and external differences.
It is still possible to swap it in a truck though as it was also in other rwd applications. Your going to pay a lot more for a GN engine to I bet. Posted via Mobile Device
