LED King
I'm not moving anywhere . . . Smoke stopped me
Today as I was coming home, I had the A/C on and the compresser was making funny noises. I got into town, & I smelt something funky. Smoke started coming from the hood & I check my temparature. I was fine. I knew it was my compressor. I pulled into a parking lot, let it cool for a while & poped my hood. My A/C compressor was green, yellow, and white and smoking. It smelled like .... I dunno! Rubber & ass or something! The thing also sprayed grease or oil around too. What is this stuff? I know the thing was going to go out eventually go out - it had always made a little extra noise. But just before summer!?!?!?!?
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
I put a ounce of two of oil in mine every few years but there is no way to tell if that is why my 1984 still has it's factory compressor.
I am suprised yours did not lock up and throw the belt. It clearly died. Save what's left and use it for your core though. I can tell you one thing. Don't get a compressor at a Autozone if you are going to stick with R12. I did a few years ago for my Z/28 and after putting three on from them (and charging them all with 4 cans of R12 each) I finally got one that was not locked up. That would be waay expensive today. You could go with a GM one but the price will kill you and it will probably be a rebuilt one too. You are going to need a flush followed by 1 hour of vacumn or the new compressor will fail real quick. You will also have to go with a new dryer but you will find that out as many places will not sell you a compressor without a new dryer. I would first find out why the old compressor failed. Was it cycling the compressor on and off? The noises you mentioned tell me might have ran out of oil and something inside went. If the freon was low then this can happen 'cause the freon carries the oil. When was the last time you added any R12? I bet you have a leak somewhere and that has GOT to be fixed first. Now would be a real good time to go over to R134 as if I sold you the freon you would need 4 cans at the least. Thats' $140 without the shipping. Add $30 for the haz. fee to ship the stuff. I would also need a copy of your license to buy the stuff. I hate to say that but would you pay the EPA fine for me if something happened? Around $250,000? Go with the R134 and you can get it even out there without the expense and the hassle. |
LED King
I got a used one from the junk yard (no telling how long it will last but is has really good compression)
My questions: Do I really need a new dryer? (& what is its purpose?) We had been told years ago it was dieing, but just would deal with it when it happened It is almost locked up - almost there - frosted the belt - something inside probably went Freon probably wasn't low because it was recharged two years ago - I really don't think it has a leak What do I need to convert to R134? Can't I just reuse the freon I have? If I can't - why not? Not only did this thing happen, my truck refused to start once I got it home ![]()
#4 | |
It's purpose is to take out the water in your system because water and freon when mixed together form a strong acid that will kill the compressor and everything else in your A/C system. The debris in it comes from the breakup of the compressor internals that caused the compressor to fail. That is two seperate reasons to get a new one and they don't cost that much anyway. That you can get at a Autozone or the like.When you get it...DO NOT take the seals off until the install. If it does not have seals on it when you buy it= run as fast as you can from that store. You can reuse the freon you have if you have a collection machine that cleans and stores it long enough for you to fix the original problem. They run $1500 or so. It is not a liquid you can pour out and pour back in. It is a high pressure gas. You have to change the compressor right?, You will lose all your freon. To convert to R134, get a conversion kit from a parts place and read the directions. They all differ too much for me to tell you. You will still have to flush the system to get the junk out. The old oil needs to go too so you can use the right oil for R134. The flush will do both for you. You will also have to pull a vacumn on the lines for about a hour (if the vacumn pump is strong) or longer. This is done after you have all your parts installed and just before you add your new oil and freon. Miss this step and BYE-BYE whole system. If you have never done this type of work I would highly recommend you hire it done. These systems are too carefully balanced to be throwing parts at. I see far too many people miss the steps above and then bring it to me to fix. When I tell them the cost they usually give up on it. EVERYTHING has to be replaced usually. If you have anymore questions on this please ask. You need A/C where you live! |
Take it to the limit
Good job Mike,you answered all the questions i had about A/C systems.Was too shy to do a post though.getting the whole system gone through within the next couple months .i might pm you when the time comes for questions.
1995 GMC SLE Ext cab 4X4 Z-71 loaded daily driver 87 k25 Fully Loaded inc captain buckets and console,12" susp lift,3" body lift 42"swampers 66 Cutlass 2dr hardtop currently undergoing frame off 55 chev 2dr hardtop awaiting attention 85 Chev silverado 1/2 ton loaded,daily driver(stolen) 80 chev silverado 1/2 ton farm truck 87 S-jimmy V-8,lowered ,Parting out 49 Chev 1/2 parting out parting numerous 73-80 chev trucks 01 Polaris edge X (highly modified) 58 NSU Prima scooter awaiting total restoration |
#6 | |
PM, email or post them and I can probably help you on A/C stuff. Thanks |
BAD BOW-Silverado XST
I converted to R134. Best money I spent for a cold A/C!!
LED King
That answered all my questions! I am definitely going to hire this out - I want someone to blame if it fails again! This is alot to digest. I need A/C where I live? YOU BET - Black truck, black & chrome interior, in CA w/ 100+ weather . . . I toast! Just today sitting outside for an hour it got to high 90 inside.... I burnt myself on the seatbelt!
BTW: Thank you for answering my questions! This will probably answer everyone's questions an A/C for a while. I always noticed alot of 81-87 trucks original A/C is never fixed & left broken - now I see why . . . ouch!
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 Last edited by apstguy; 03-30-2003 at 02:56 AM. |
apstguy,
Glad I could help indeed. Get a few books off of eBay on car A/C systems and you won't have to hire your next one done. Good luck! |
#10 | |
Re: I'm not moving anywhere . . . Smoke stopped me
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
A/C
I have no A/C : I have no problems...
Freon 12 is forbidden now in Europe Just get the windows open , wear a short... ![]() The Baron 79 C10 LWB 77 Impala Sedan |
#12 | |
LED King
Re: Re: I'm not moving anywhere . . . Smoke stopped me
LED King
Update on today: Not only did this crap happen but even more today!!!!
![]() I installed the new battery cables this morning. I go to start the truck and :grrt: all I get is a noise. @%$&$!!!!!!!!!!!! So I charge the battery for a good 4 hours and try. :grrt: nothing more than before I charged it!!!! I take the battery out of my mom's Tahoe & try. Starts up no problem! So I narrowed it down to the battery. I take the old battery down to Kragens (where it was from & still had 3 years on the warrenty) 1/2 hour before they close. They test it and say it is a perfectly good battery. I tell them they are wrong. No effect. They put it on a charger for 10 min. I head over to Autozone just in case the battery doesn't work & buy a small Optima battery a few min. before they close. I get home and put in the old battery & NOTHING. I put in the new battery & PRESTO! It's alive! MUUHAHHHA!! By not it is 8pm. I stick my stero back in (took it out so no one could steal it last night b/c my alarm doesn't work without power) and my stereo works. Try to eject the CD, but it won't. I try to play the CD & it won't!!!! ![]()
Man Tyler!!!
Who upstairs did you piss off??? LOL The CD player won't do much eh? Has it got a reset button on the back? Sounds like a major electrical problem hit it. I am trying to tie all your problems together but I don't know dude. Your compressor gets so hot that it pukes and that would (?) get your condensor hot which could overheat your engine so it just about locks up too and you park it and try to start the now "tight" engine and the cables fry and your battery plates warp from all the current you were trying to pull. You try a boost with another battery and this sends a voltage spike that scrambles the CD player. This works pretty good except you said your engine temp was good when the compressor went. Heck I don't know......... One thought though, before this A/C "event" happened, were your battery cables in decent shape? I mean did this change in them happen all at once? |
#15 |
$640 truck// doesn't run
Mike76251 thanks for the info,I am attending an HVAC service class this week so I will be learning more about these systems.
But your info has brought up some good questions for my instructor. Not that you can't answer them but since I am at school I might as well ask them right? Well thanks again and if he can't answer them I will post a question if I come up with some. Dave ![]()
74 C-20 LWB camper special stock350/350 53 Chevy 1/2 ton- in California, where the rust is not. Ready for some LOVE!!! |
#16 | |
I will be happy to answer anything I can for you. I have never believed knowledge was "exclusive". I will pass on another tip I have used over the years; (see if he knows this one) When you go to fill a cars' system with the little cans, get a bucket of hot tap water and put the can you are using in the hot water to speed the transfer of freon. It turns a 45 minute job into 15 minutes. Just be sure to put the end of the can that you have your hose hooked to UP. You don't want to pull any liqiud into your compressor while it is running. |
#17 |
Oh no, this holding the can up thing, is this on 134 and r12???
My Dad always holds the can upside down and shakes it ![]()
Chris '92 ext. cab s/b 4.3L "Sparky" '04 crew cab 2500 4x4 6.0L |
#18 | |
LED King
I really think the world doesn't like me anymore. I pushed the reset button on the CD player, but it does jack. I'm just going to dissasemble it & take the CD out & pray it still works. I think what happened is when the compresser froze, it spiked the electrical system by putting alot of strain on the electromagnet. The battery cables where rather old, an I had know they needed replacement for a while. The problem with the CD player is it worked after the compressor puked. I think when I pulled it out I must have jarred it & got the CD stuck in there. I notice I have more juice in the electrical system. They tested my battery again, & said one of the cells died. Oh - with the new Optima battery, I got the small one because it was $60 less than the regular red top. Is this a good thing or do I need the full size battery?
#19 |
LED King
I have been asking around and from what I can tell is keeping with R-12 will be bad in the long run. I'm going to convert to R134. I'm going to take the compressor I bought from the junkyard & get my money back and get a rebuilt one. From what I am told, I will also need to get a new dryer (does a dryer have a different name? I can't find one in the LMC magazine) and a new oriface tube. I'll need to have it flushed, then vacuum tested. It will then be ready. From what I can tell ,this whole thing is going to cost somewhere from $200-$500. UGH! Do I have all my info correct?
#20 | |
I have had too many bad rebuilt ones and all I can tell you is make sure it has a warranty and you save the reciept. Good call on the 134. It will save you money now and later. LMC probably doesn't sell dryers because everybody else does and they would find it hard to match the price. They mainly sell resto stuff and this is not really resto. You are not really testing it with the vacumn but pulling out all the moisture you can. It doesn't take much to ruin things quick. The vacumn needs to stay on for at least 45 minutes. I hope the shop you take it to will do that. I am sorry I did not get this reply back sooner. For some reason the new message indicator did not show and I just happen to stop by here. You can email me if you need anything answered quick. Good Luck once again |
#21 | |
If the CD is wedged out of it's holder it won't eject or play. Just take the top off and see what looks "off". If you have the pinouts you can hook 12v up to it and really tell whats up. I have one of those "little" Optimas in my truck. I love it.....stick with that and if you drain that thing you will not need a full size battery=you will need a forklift battery!! |
#22 | |
It works on either one. Your Dad is one lucky dude.......if too much liquid goes down that line while he is shaking it will lock up the compressor. A compressor can compress gas but not liquid. Same thing happens to a engine when you get too much water in it. It locks up and throws a rod. He is shaking it to get it go in faster BTW. Tell him to get some hot water and stick the can in. Upside down of course. |
#23 |
LED King
I'm learning more and more.
![]() I have an uncle that has the equiptment to do most of this stuff so I may not have to take it to a shop!!!! YAY! ![]()
#24 | |
Glad you found a way to avoid the shop! I have only been in a shop one time in my life. If you need anymore help just post or email me Happy I could help, Mike |
