Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-22-2011, 12:41 AM   #1
Super73
Super73's Avatar
New motor and Trans work (104-105mph in the 1/8)..
I have been dealing with a few minor issues here and there and just got done with a fun day of racing in Dos Palos. This is the event where there are no clocks, 1973 and early, arm drop 1/8 mile. Traction is always a little bit of an issue because it gets breezy and it's dusty, but it sure is fun!!
If my G-tech RR is right (which it's consistantly about .1 and 1mph optamistic compared to the track), the two passes that I used on it looked like this:
Rolled in to throttle and did not have to lift
60' = 2.03
330' = 4.988
1/8 = 7.373 @ 105.25
Rolled in to throttle and had to peddle it about 60' feet out as it started to go sideways.
60' = 2.01
330' = 5.076
1/8 = 7.50x @ 104.12
Obviously I have to throw the ET out a bit do to the major traction issues, but that mph tells me it is making the power it needs to to go in to the 10's on motor. What's that old saying .1 in the 60' is .15 on the big end.. Even if it's .1 for .1, the first pass says it is there being it's gone 1.59 with out everything it had with the old motor, smaller verter and more weight (and a steeper 1st gear).
I have a few videos I'll post after I reduce their size a bit.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-22-2011, 01:08 AM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: New motor and Trans work (104-105mph in the 1/8)..
Very nice times! It sounds like it's starting out great!
Ryan
1969 Chevy milk truck
Old 05-22-2011, 10:45 PM   #3
djracer
djracer's Avatar
when you make it to a better track and get the new times for your Signature?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 05-22-2011, 11:52 PM   #4
Super73
Super73's Avatar
I am affraid it will not be before September. Truck should be getting dropped off in a few weeks for the cage, and I will be doing the summer school semester. Then we have a buch of things planned in August. Maybe I can get the truck rewired and get the N20 controller hooked up before September
Old 05-23-2011, 01:16 AM   #5
djracer
djracer's Avatar
what are you thinking about to control the nitrous and what type of wiring setup.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 05-23-2011, 01:52 AM   #6
Super73
Super73's Avatar
I bought a NOS Launcher which with the single unit it will control two stages over time/percentage. It can control 4 stages with an add on and also kill the N20 based on a wideband reading (again add on needed).
From the looks of the NOS wiring diagram: http://static.summitracing.com/globa...s-15976nos.pdf it looks like the launcher grounds the noids (guessing based off a pwm).
I will run an arming switch for both stages then ground through the Launcher.
I will most likely have a relay running to the launcher as the activation from the trans brake.
I really need to draw it all up. Suggestions?
Old 05-23-2011, 07:46 AM   #7
djracer
djracer's Avatar
If you don't mind programming with a laptop look up the FJO progressive. I think its only like $220.00. Its easy to use and pretty cheap. My friend with the orange 67RS Camaro has one and its sweet. I have not played with these but they look like they may be made by Fjo. I used one of the older Nos units and it sucked.
Are you rewiring the entire truck?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 05-23-2011, 08:25 AM   #8
99-LS1-SS
99-LS1-SS's Avatar
Wow! When you get traction out of the hole you'll pick up a lot! I bet that truck is a lot of fun to drive.
99-LS1-SS is offline   Reply With Quote
Old 05-23-2011, 11:40 AM   #9
Super73
Super73's Avatar
Yes I will be rewiring the full truck. I bought a full universal harness that has 21 or 22 circuts so I can wire up the N20 off of it too (I'll use the power window/door lock circuts).
What N20 controller were you using from NOS? Sure hope this one works good..
Old 05-23-2011, 11:55 AM   #10
Super73
Super73's Avatar
Here is a little video someone took on youtube.. I have finals today so I'll get mine up later.
http://www.youtube.com/watch?feature...&v=mCRnNqHag7Q
Old 05-23-2011, 02:41 PM   #11
Super73
Super73's Avatar
Hopefully this works:
Old 05-28-2011, 07:37 PM   #12
team39763
That was cool. Once you got off the line that power kicked in nice.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 05-29-2011, 01:09 AM   #13
Super73
Super73's Avatar
It definately pulls harder than it did with the other motor. Wish I could have hit it out of the hole with everything it had, but that was not the case. 2nd week in september, hopefully I can..
Old 06-04-2011, 07:32 PM   #14
taank
I have 518 at the motor 284 lift cam. What converter would you suggest. Th350 trans
taank is offline   Reply With Quote
Old 06-04-2011, 10:39 PM   #15
Super73
Super73's Avatar
Not sure I am following you completely. I am assuming you make 518 hp on an engine dyno. As far as you cam specs, I'm assuming 284* duration, but at .006, .020, .050 and you are not stating lift.
Who makes the cam and what grind is it?
What RPM did you motor make peak TQ and peak HP?
Old 06-05-2011, 11:20 AM   #16
taank
It's a comp cams extreme energy 284 hyd flat tap.
Peak hp was at 6100 if I recall
Peak torque was at 4500 if I recall
I can attach the dyno sheet later today if that would be best. It currently has a 2500 stall. But with 295 65 15 drag radials it leaves soft and won't spin hardly. It's a real fog off the line.
Old 06-05-2011, 12:30 PM   #17
Super73
Super73's Avatar
Do you want max acceleration with sacrafising driving a little? Go with an 8" converter stalled to your peak TQ.
Old 07-18-2011, 06:24 PM   #18
LUNATICS
LUNATICS's Avatar
awesome..im new to this forum, looking for some help with 60-66 style trucks, im setting one up to drag and play on street, was wondering if you or anyone else mind sharing info such as suspension mods
LUNATICS is offline   Reply With Quote
Old 07-18-2011, 07:45 PM   #19
djracer
djracer's Avatar
read this
http://67-72chevytrucks.com/vboard/s...d.php?t=326863
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-18-2011, 08:34 PM   #20
LUNATICS
LUNATICS's Avatar
i did read...lots of info in there, has anyone removed the entire front crossmember and stock suspension and install tubular control arms with coilovers , kinda like a mustang 2 setup?
Old 07-18-2011, 09:47 PM   #21
softballnrd27
Always a work in progress
softballnrd27's Avatar
New bern huh, I live in havelock and play softball in new bern. We will have to meet up one wekend.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 07-18-2011, 09:58 PM   #22
Super73
Super73's Avatar
To answer your question, there are several guys with aftermarket fronts. DJ has a Fatman Mustang II, KP has a one off set up that he is producing and selling, others have made their own Mustang II front, and others are using aftermarket tubular arms made by Classic Performance.
Old 07-18-2011, 10:16 PM   #23
LUNATICS
LUNATICS's Avatar
The softball guy..ive seen your 85 around..yeah we will have to meet up..think you got your truck from darren?
Old 07-18-2011, 10:20 PM   #24
LUNATICS
LUNATICS's Avatar
Super 73..ive read alot of your posts...seems you got you sh*t togather! Way advanced for me...i had a 93 stang and let me tell you that is easy to get to hook up and goes straight...this "kp" is there away of contacting and get an idea of price? For me its all about the weight but primarily cost as well...i appreciate everyones input and advice!
Old 07-19-2011, 12:07 AM   #25
Super73
Super73's Avatar
Look up kpeztruck on here. He has a thread in the racing section showing pics of his front end..
