Old 03-29-2003, 07:44 PM   #1
swervin ervin
You get what you pay for
swervin ervin's Avatar
Smile She's at 4/6
My flip kit came yesterday, and it's on today.
I did have 4" leafs, and used the top hole in the shackles, for a drop of around 5". I measured everything today before starting. It was 27.5" all the way around. After I flipped it and put my old stock leafs back on, again, putting the back of the leaf in the top hole in the shackle, it was still 27.5" in front of course, but the back was now 25.75".
Hmm... this amounts to 1.75" lower. It looked to me, and it may have been my eyes playing tricks on me, that the back was too low. If my previous measurements were right, and I think they were, this would mean I was now over 6", by about a 1/2". I went back and put the rear of the leaf in the lower shackle hole. This moved it up 1/2", to 26.25".
Anyway to the point. I now have measurements of 27.5 in front, and 26.25 at the rear. I'm pretty sure there is a difference of 1.25" in front and rear fender well lips, so this sounds right.
So, what do you 4/6 guys have for measurements? It don't matter what size your tires and wheels are, I only want to know how much difference you have in yours.
It looks a lot better I think. I'll get some pics tomorrow, it's about dark here now. I'll probably get a C notch now. I only have around 2.5" left between the axle and frame. Not enough I don't think. I don't want to go banging on the frame. I removed the bump stop too.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 03-29-2003, 08:15 PM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
Sweet! My frame is notched using WC's kit and it's awesome.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 03-29-2003, 08:22 PM   #3
gldevall
gldevall's Avatar
Well I'm not sure how much this will help, considering I have the 4.3 in it. But, here are the measurements I took
Front Driver 27 3/8"
Front Passenger 28"
Rear Driver 25 7/8"
Rear Passenger 26 5/16"
This is the first time I have taken measurements. Should there be this much variation in them? Also, these are from the ground to the wheel well. Hope it helps.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 03-29-2003, 09:14 PM   #4
swervin ervin
Gary,
sounds similar to what I have. As to the difference between side to side, do you have a full tank of gas in the drivers side and empty on the passenger? Mine has always done this unless both sides were about empty or full.
Old 03-29-2003, 11:37 PM   #5
swervin ervin
Well, no doubt, I'm going to install a C-notch. I drove my truck tonight and was hitting the frame a little. We have some terrible roads in this neck of the woods, so no way to get around a notch.
I'm really liking the new level stance.
Old 03-30-2003, 12:16 AM   #6
C&C Chevy
C&C Chevy's Avatar
Can't wait for the pics!
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 03-30-2003, 04:34 AM   #7
bill_ont_canada
Nobody is perfect...
bill_ont_canada's Avatar
Hey Mike, try to get some pics when you are installing the notch, it could be a good "how to" for those of us who have not done it yet.
Just a thought...
Have a fabulous day.
Bill... (ö¿ö)
" Loud Pipes Save Lives "
bill_ont_canada is offline   Reply With Quote
Old 03-30-2003, 09:10 AM   #8
Razorback_Fan
Razorback_Fan's Avatar
The fun never ends with these trucks does it
Razorback_Fan is offline   Reply With Quote
Old 03-30-2003, 07:09 PM   #9
swervin ervin
Here's how she sits now. What'cha think?
Old 03-30-2003, 07:12 PM   #10
swervin ervin
Here's another from the other side.
Old 03-30-2003, 07:27 PM   #11
low 84
low 84's Avatar
Just a thought...
i already did that, heres a copy
First thing is to have the flip kit installed and the wheels on the truck and the truck on the ground. this way you can mark the exact center of the axle on the frame so the notch will line up with the frame correctly. The next thing i did was make a templete out of card board the same size as the semi-circle part of the notch that goes through the frame. I used a level and stood it straight up on the axle, with the straight edge of the level lined up with the certer of the axle tube. The level should show you on your frame exactly where the center line of the notch should be so your notch is centerd correctly. scribe this center line on the frame. then take your templete and line the center of it up with the line on your frame and trace it on there. BEFORE YOU CUT: be sure to have the frame supported on both sides of the notch, and only do one side at a time, one side needs to be completely done and bolted in before you cut the other side. okay now you can cut, i used a grinder with 4 1/2 inch cutting wheel
okay now after you have it cut slip the notch on and use clamps to hold it in place
now you can start drilling the holes, you'll need a good hard metal drill bit. each time you drill one hole go ahead and instert that bolt and snug the nut up, this way you know all of your bolt holes will line up. torque them all to spec.
put you bumpstop on and your set.
inside view
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-30-2003, 08:36 PM   #12
ocbaud
Garage Queen Material
thats the one thing i had over your truck, the drop, now i dont even have that:p
ocbaud is offline   Reply With Quote
Old 03-30-2003, 09:41 PM   #13
BaggedC10
Under construction!
BaggedC10's Avatar
Yep, and his truck looks a bit lower than your's now too. :p
Old 03-30-2003, 10:18 PM   #14
gldevall
gldevall's Avatar
Looks GREAT Mike!!
Old 03-30-2003, 11:54 PM   #15
ocbaud
smaller tires he has
Old 03-31-2003, 12:23 AM   #16
84Stepper
84Stepper's Avatar
Lookin great Mike!
84 Chevy Stepside, 350, TH350, 268h
Comp cam, Hooker headers, MSD
Pro Billet, Edelbrock Performer manifold
and 1604 carb, 40 Series Flowmasters
dumped, and Western Chassis 3/5 drop w/ c notch. New 3:73 Eaton Posi
84Stepper is offline   Reply With Quote
Old 03-31-2003, 12:45 AM   #17
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
All I want is a RIDE!!!
Nice stance Mike.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-31-2003, 01:44 AM   #18
1FaastC10
1FaastC10's Avatar
i hate to be the first one to go against the grain here... but i dont like it. needs to be lower, i'm sure ART is looking forward to your business :p
1FaastC10 is offline   Reply With Quote
Old 03-31-2003, 03:49 AM   #19
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I really like the stance there Mike But if you're going to notch it I agree with Jeremy you know the bug will bite you to go with bags. Might as well do it then
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-31-2003, 09:33 AM   #20
Low87
been here longer than Liz
Low87's Avatar
Looks perfect Mike! Nice and level.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 03-31-2003, 09:41 AM   #21
BigRed
I think it's perfect. I wouldn't go any lower. Nice and level, good stance! Very sporty.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 03-31-2003, 01:45 PM   #22
TIMSPEED
TIMSPEED's Avatar
Hmm..On my truck, I got 27" Measurement all around, and I only have a 3/5 drop with 255/55 17's...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 03-31-2003, 01:56 PM   #23
bigblock73
yeller
bigblock73's Avatar
Looks awesome Mike!
good job!
-Jeff
bigblock73 is offline   Reply With Quote
Old 03-31-2003, 02:58 PM   #24
swervin ervin
Thanks guys.
I ordered the C-notch this morning. Will probably get it installed this coming weekend.
Old 03-31-2003, 03:03 PM   #25
TIMSPEED
TIMSPEED's Avatar
Thanks guys.
I guess that 1" makes all the difference, with my 5" DJM Flip Kit, I have about a SOLID 4" between the axle and the frame. (and all my fenders measured out to 27")
See Them Here
