Old 05-23-2011, 01:48 PM   #1
camarossrulz
oil pan question
so will the stock oil pan on a fbody ls1 work on a 72 2wd? I have searched and read many post on this and Im still a little confused.
1972 C-10 short bed, 2wd, 350(ls1 coming soon)
1969 camaro ss, 496 stoker, 4sp
2009 crew cab,duramax 2500hd 4x4, lifted (sold)
2008 Daytona Charger, Hemi Orange, 07 C6 Z06
2005 suburban, 2002 grand prix gt
2005 grizzly, 2004 R1
camarossrulz is offline   Reply With Quote
Old 05-23-2011, 02:37 PM   #2
Clyde65
Clyde65's Avatar
Re: oil pan question
stock truck pan will work just fine, is it lowered and if so, how much?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-23-2011, 03:11 PM   #3
camarossrulz
its stock in the front and lowered 2 inches in the back, I just didnt want to buy a new pan if i didnt need it
Old 05-23-2011, 03:17 PM   #4
Clyde65
Clyde65's Avatar
if you plan on lowering it, like a 4/6 eventually or even lower, then yes it would be a good idea to do it now. If your not going to do that, no way no how etc.etc, then a truck pan will be fine, my truck pan sits about 1" below the cross member.
Clyde65
Rebuild of Clyde
support our troops!
Old 05-23-2011, 04:16 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Clyde, he's referencing the F-body pan if I read it right.
F-Body is 5 1/2" deep and the truck is 8 1/2" deep. He should be fine with the depth on the fbody pan as long as the shape clears the crossmember. I have the LH8 pan, and its about 3/4 LOWER than the skid plate/xmember. I'm lowered 4/6 (maybe a bit more) and its fine, but a bit nerve racking on speedbumps or big dips.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-23-2011, 05:06 PM   #6
Clyde65
Clyde65's Avatar
Yea Br3, I figured that but I was just currious if he was planning on lowering it more, if not, then why buy the fbody pan? stick with the truck pan and he is still good to go.
If he plans on lowering it alot, then the fbody or the LH8 pan would be the option.
Clyde65
Rebuild of Clyde
support our troops!
Old 05-23-2011, 11:52 PM   #7
ls1nova71
ls1nova71's Avatar
If I'm reading this right, his sig says 'ls1 coming soon' so I would assume he's getting an ls1 out of an F-body. I think that pan might be hard to use in a truck because the sump part of the pan extends too far forward. You would either have to move the engine back further or maybe try to raise it up to clear the crossmember. The Hummer pan or truck pan would be easier to use, although they do hang about an inch below the crossmember. But even if the pan is higher than the crossmember, it's still not completely safe from every road hazzard, my Nova the pan is higher than the crossmember, and I have a broken oil pan to prove it.
ls1nova71 is offline   Reply With Quote
Old 05-24-2011, 06:34 AM   #8
camarossrulz
I have a complete ls1 out of a 00 formula, I was wondering if the stock pan that is already on the engine would work, or if I needed to buy the lh8 pan. I havent started the swap yet, so i was trying to see if i need to change the oil pan or if the stock one would work. I have no plans of lowering the truck. Another reason I was asking is that I have a guy that is wanting to buy the fbody pan if I take it off. I appreciate everyones help. Sounds like I would be better off to go ahead and put the Lh8 on it.
Old 05-24-2011, 09:11 AM   #9
ls1nova71
ls1nova71's Avatar
I would go ahead and sell the F-body pan, they will bring between$ 150 and$ 200.. and a truck pan can be picked up for about$ 50. It would save you some on your swap, and most likley be easier.
Old 05-24-2011, 10:06 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Get the swap pan/lh8 pan. The truck pan works, but the larger size makes fitment a little tighter. If your putting the engine and trans in together, the extra clearance on the front of the pan is a godsend when maneuvering around the core support.
Old 05-24-2011, 11:35 AM   #11
camarossrulz
I think I will get the lh8, my oil pan is the fbody one
Old 05-24-2011, 05:44 PM   #12
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
My pan is the stock LY6 pan and fits good other then hanging down below the crossmember a bit...as do the headers
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-25-2011, 03:36 PM   #13
Hart_Rod
Hart_Rod's Avatar
It all depends on the motor mounts you use. If you go with ECE mounts, the Fbody will not work. You'll need to use the CTsV pan or the H8 pan. If you go with Street and performance or CPP style mounts the Fbody pan should work with no problem.
Hart_Rod is offline   Reply With Quote
Old 05-26-2011, 10:03 AM   #14
Shon
I have the truck pan and mine is lowered 3/4 with springs.
check out paceperformance swap kit, i think its the Hummer pan but everything is like $150.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 05-26-2011, 12:34 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
ya, its the hummer H3/LH8 pan with the pickup tube and windage tray etc. Not bad for the price.
Old 05-27-2011, 12:10 AM   #16
5150.4.67
If you must use the stock truck pan, put a skid plate on as well.
5150.4.67 is offline   Reply With Quote
Old 05-27-2011, 11:37 AM   #17
68GMCCustom
plan on getting a different pan for mine when I get the new DT big tube headers....then everything will be within the frame rails, with nothing hanging down
Kurt -
