Old 03-29-2003, 10:14 PM   #1
78SilveradoSWB
78SilveradoSWB's Avatar
Question Glove Box or Console Door Lock Assy
How does the lock assembly for either the console or glove box removed? Any advice?
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 03-29-2003, 10:29 PM   #2
Blue Beard
Blue Beard's Avatar
The ones i've seen were either clipped or had a large nut on the back.....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-29-2003, 10:35 PM   #3
78SilveradoSWB
No clip or nut. It has 3 pieces, the lock cylinder ( the part the key goes into, a escutcheon, (part that surrounds the hole, and the lock cylinder case, the part behind the door. Wonder if there some release mechanism so I can pull it apart.
Mitch
454 BB, TH400
Old 03-30-2003, 12:33 AM   #4
twistedmetal
Take it to the limit
twistedmetal's Avatar
i just removed mine,will try to submit pix tomorrow
1995 GMC SLE Ext cab 4X4 Z-71 loaded daily driver 87 k25 Fully Loaded inc captain buckets and console,12" susp lift,3" body lift 42"swampers
66 Cutlass 2dr hardtop currently undergoing frame off
55 chev 2dr hardtop awaiting attention
85 Chev silverado 1/2 ton loaded,daily driver(stolen)
80 chev silverado 1/2 ton farm truck
87 S-jimmy V-8,lowered ,Parting out
49 Chev 1/2 parting out
parting numerous 73-80 chev trucks
01 Polaris edge X (highly modified)
58 NSU Prima scooter awaiting total restoration
twistedmetal is offline   Reply With Quote
Old 03-30-2003, 01:07 AM   #5
twistedmetal
First manually click lock to locked position
Old 03-30-2003, 01:13 AM   #6
twistedmetal
Next locate a hex key,about 1/8 " or 3/16" ,place into the slot as shown,you will have to udjust key in and out as it will be working like the cam that holds the lock in,while moving it in and out gently pry on the outside knob under the edge,not too hard or it will pop off.
Old 03-30-2003, 01:18 AM   #7
twistedmetal
the lock will now be half out and the lock will click to the open position.you will have to insert your hex key again to push in on the final cam.this is how the cams look.
Old 03-30-2003, 01:25 AM   #8
twistedmetal
you can now unthread the ataching threaded bushing(or thats what i call it)it is an 8 sided key that removes this,i didn't do it that fancy,what i used was a large flat screwdriver and jammed that in there,working carefully to not damage the cast inside.
Old 03-30-2003, 04:19 AM   #9
bill_ont_canada
Nobody is perfect...
bill_ont_canada's Avatar
Hey Twistedmetal... That looks like a great surgical extraction you just did... kinda like a Manisnowba Truck Surgeon Eh! very kool indeed.
Have a fabulous day.
Bill... (ö¿ö)
" Loud Pipes Save Lives "
bill_ont_canada is offline   Reply With Quote
Old 03-30-2003, 09:54 AM   #10
Blue Beard
Blue Beard's Avatar
Great post, also corrects some of the things I've seen...............good work........wish we had more helpful post like that..........
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 03-30-2003, 03:06 PM   #11
78SilveradoSWB
Thumbs up
Thanks twistedmetal! It worked out just great!
Mitch
454 BB, TH400
