05-24-2011, 02:03 AM | #1 |
Pictures needed of wooden truck floors!
In particular the bed floor supports. What is the correct area a step side should match up to the cab? Do the tall bed supports go in the front back or middle? Im working with a previous installed wood bed kit that never really did fit right. Is there a bushing or mount that goes between the bed and frame bolts?
Posted via Mobile Device |
05-24-2011, 06:48 AM | #2 |
1969 Custom 30 wrecker
Re: Pictures needed of wooden truck floors!
Here's a pic of mine without the box on. The thin strip setting on the tire goes about at the rear tire area.
There is a square rubber pad that goes at each bolt location between the frame and cross sill. Hope this helps...
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
05-24-2011, 10:11 AM | #3 |
That thin strip on every step bed I have seen and even on mine goes about 8 inch behind the second main bed support from the front of the truck . Its loacation is marked by the holes in the angle strip on the passenger lower angle strip thats welded to the bed side. On a couple of frames I have even seen where that small support strip has even rubbed groves in the main frame of the truck from having a lot of weight in the bed of the truck.
Tim |
05-24-2011, 01:29 PM | #4 |
Here is mine before it was mounted with the cross supports already installed. Hope this helps.
1969 C-10 short step 1981 CJ7 2017 Ram 2500 Laramie 4X4 1939 Cadillac LaSalle sedan 1950 Allis Chalmers B 1998 Bullet 21 XD 300 Merc/water hot rod |
05-24-2011, 09:03 PM | #5 |
This is one of Trex... a wood decking composite. Should outlast the truck!
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 |
