I have a swb 86 with a 350, I want electric fans but know NOTHING about them.. Can someone help?
Re: Electric fans? What has everyone decided?
Mark VIII dual speeds fans. You can run low and high independantly.it's also 18in, one of the bigest fans u can get
The One And Only !!!
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
#4 | |
El Mero Mero Frijolero!!
http://cgi.ebay.com/ebaymotors/91-95...item5ae01a4f03 This makes wiring SO much easier, wish they had this when I installed it. http://cgi.ebay.com/ebaymotors/Tauru...item1c1c013622
My Toys: 1993 Ford Mustang LX 5.0 2001 Yamaha V Star 650 1984 Silverado > Build Page < |
I'm happy with my Flex-A-Lite 295 Kit. Only change I made was to swap to the temp sensor that goes in the cylinder head instead of the radiator probe. It made it better.
![]() ![]() ![]() ![]() I got this complete for $380 or so. They normally sell for like $500+ I just hunted for a deal for a while and finally found one, but then again I didnt have the time to piece together a setup. I kinda needed to slap it in and forget about it. |
Okay, where would I go to get something like these fans?
Ebay, junk yards ect......
Thanks man!! I will go look soon!
I got my dual fans off a chrysler 300 (I think) and with a little fabrication they fit right in my stock shroud and picked up a relay at O'Reillys, a fitting for the temp sensor in the fitting on top of the water pump. Works great, looks stock (unless you really look) and did it all for around $75.00.
I got a brand NEW Jeep fan delivered to my door for $73 and change from here;
http://www.chryslerpartsdirect.com/ You may have to click the link a couple times, It appears they have site issues at the moment. You can pick up a relay kit from most any auto parts store or Summit and Jegs....
I hear that these jeep fans go out frequently? And does that fan have everything that I need?!
![]() Join Date: Dec 2010
Mine are dual electric fans & they are built into the radiator shroud. This set-up is from Ron Davis for my LS swap.
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
Now that is cool!
#14 | |
Did you not read the thread I linked ? There was a factory recall for broken blades on some fans; http://www.wjjeeps.com/tsb/recall_f25.pdf The new up-graded fan solved the issue, That's why it's best to buy new instead of just any used efan from a JY. Again as the linked thread shows, All you need is three screws and nuts to install the efan and a relay kit as I mentioned in my second post. All you get is the efan in a box from Dodge/Jeep.
#15 | |
#16 |
I entered the new part# from the recall notice CBG4F250 in the "Search By Factory Part Number" box, Then clicked on the blue down arrow box and selected Jeep. Ordered it right then and there.....
#17 |
US Army Veteran
![]() Join Date: Nov 2008
Just picked up a Mark VIII fan off Ebay. I had a flex-a-lite 210 setup, but it was not enough to cool my 383 stroker.
1972 C10 Highlander - The making of a daily driver |
#18 |
Addicted to Rust
![]() Join Date: Dec 2009
Lincoln fan int a stock Big Block shroud.
http://67-72chevytrucks.com/vboard/s...d.php?t=425728
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
#19 |
That's a Very clean install! I like it a lot
#20 |
so, I want to use the Jeep fan set-up. How would I do this and still have the AC hooked up? Is this even something that I need to be concerned about? By the way I have a 86 c1500.
#21 |
I haven't had time to install mine yet but my plan is to run two relays. One off the AC clutch wire so the fan comes on/stays on when the AC is turned on, And the other through a thermo switch in the intake for when the AC isn't used.
#22 | |
US Army Veteran
We used the Dakota Digital PAC-2700 fan controller along with the Lincoln Mark VIII fan. It's setup so that you can wire in to come on with the AC if desired and setup for dual or single fans. We replaced the standard 70 amp relays (because the blew!) with ZETTLER Super ISO Relays (AZ9801-1A-12D) that are 70 amp (you would have to order these online, not very common), and can handle up to 500amp momentary draw. The Mark VIII fan draws upwards of 100amps on startup, for about a millisecond, then levels out to about 30 amps continuous. Posting a little more information than your question requires, in case anyone else has the same issue with overheating. I was using a flex-a-lite 210 electric fan setup with controller and having overheating issues. The fan worked beautifully, but it was just not enough CFM going through to cool the beast. After swapping it out for the Mark VIII fan, which has a low and high speed, we drove around Saturday in 100+ degree weather. Never could get it warm enough to kick in the high fan. When the low fan came on at 185 degrees, the temp would start going down almost instantly and never would get hot enough to kick on the high fan at 195. A cheaper alternative might be to use a Hayden fan controller with a rated relay for the draw on your fan.
#23 |
We use Ford taurus fans in our rock crawlers and they move A LOT of air. They are two speed and really keep things cool.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
#24 | |
![]() Join Date: Jan 2010
Thanks for the help. |
#25 | |
US Army Veteran
There are a couple of guys that sell relay kits specifically for the Mark VIII fans. I almost went with one of them, but really liked the Pac 2700 because settings can be digitally set. If you go with the Pac 2700 fan controller, though, you would need to get one of the relays I mentioned because we blew the default 70 amp that came with the Pac 2700. I've driven my truck several times for extended periods in city traffic since I posted above, and the fan is keeping it very cool. We see 105+ temps every day. Before, I could barely drive five miles, and was sweating at stop lights over the temp, but now, it doesn't go past the half way point on the temp gauge. When it gets there, you can watch it go back down pretty quickly.
Tags |
chevy truck, electric fans, help me please |
