Old 05-27-2011, 12:42 PM   #1
slikster
side trim removal?
I have searched for trim removal on google and here but couldn't come up with anything. I want to start pulling the trim off the side of the 66. Most of it is still in good shape so I don't want to ruin it trying to do it the wrong way. Also can you buy replacement trim?
slikster is offline   Reply With Quote
Old 05-27-2011, 01:09 PM   #2
jimmydean
jimmydean's Avatar
Re: side trim removal?
The trim is hard to find in good shape (at least for long beds) but it's held on with nuts on the back side. I have most of mine off, kind of a pain to take off while the sheet metal is on the truck. But if you pull the bed and fenders apart, it's a lot easier.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-27-2011, 01:19 PM   #3
Surfdaddy
Surfdaddy's Avatar
I was thinking the same about the rear cab trim. I have beeen told that it's really rare to find in good shape and mine is perfect. How can I remove it without bending or denting it. I know they make a tool for removing trim but I don't know if it's universal or not.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 05-27-2011, 01:44 PM   #4
jimmydean
jimmydean's Avatar
I think the trim tool is for pop-on trim. I don't have any pictures, but it uses the sheetmetal nuts. On the trim side, there is a football (kind of) piece that holds the screw side on the back.
If nobody has pictures handy, I'll take some when I go home at lunch and post up. To get it off clean, I loosened all the nuts but left them on until I had them all loose, then took it off as one piece.
Mine is pretty banged up, I am making custom trim for mine.
<edit> Not sure how to get to the rear cab trim, I could get to the back side of all mine.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-27-2011, 04:15 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
I also have the rear cab trim...it is held on by wire-type snap-in clips, so using a wide, flat removal tool will help from bending the trim.
Most of the side trim is fastened via molding bolt fasteners with speed nuts.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-27-2011, 04:38 PM   #6
jimmydean
jimmydean's Avatar
My thinner lower bed trim is like that, too. Forgot about the spring clips.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-27-2011, 06:27 PM   #7
rbar
rbar's Avatar
The rear cab trim is really rare. I have read it only came in 1961, but that was on a blog. I haven't sewn one in person that I can recall since I started driving these trucks in 87. MAR-K makes great side trim and needs to make that back piece.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 05-27-2011, 07:04 PM   #8
Turkey
Turkey's Avatar
I just pulled all of my trim off and found both snap and nut/bolt clips. The nuts can be hard to reach, but it is possible to remove all of them by yourself. My shoulders were on fire all afternoon, but that's the price of being to stubborn to call a few friends. Check LMC for replacement trim.
Turkey is offline   Reply With Quote
