Old 05-27-2011, 11:36 PM   #1
hensonjd
rhino liner on floor?
Anyone ever pulled their carpet out and put rhino liner on the floor. I would like to see some pics and get some pros and cons on this. thanks
hensonjd is offline   Reply With Quote
Old 05-27-2011, 11:41 PM   #2
justinburnett
justinburnett's Avatar
Re: rhino liner on floor?
I'm thinking about doing that too, actually. Although I intend to put carpet back in afterwards but I would feel better knowing even if it got wet it would be okay.
justinburnett is offline   Reply With Quote
Old 05-27-2011, 11:47 PM   #3
slammed90
slammed90's Avatar
i was thinking of the same thing to keep it from rustin after it gets fixd
slammed90 is offline   Reply With Quote
Old 05-28-2011, 12:30 AM   #4
Gyawo
Give me a month or so. I will be doing something like that in my '86 K5. Cons will be the noise, no insulation or carpet to damper road noise or from the truck itself. It will not help in keeping the cold out during winter either.
Gyawo is offline   Reply With Quote
Old 05-28-2011, 12:42 AM   #5
Eldubya
Just got my truck back from the body man, and thats exactly what they did to my floors as well as part way up the back wall. The floors will be covered by the carpet and a speaker box will eventually cover the back up. Looks good, but I don't have a motor in so I can't really comment on how well it dampens noise or anything like that....
Eldubya is offline   Reply With Quote
Old 05-28-2011, 12:43 AM   #6
woodwright
Enjoying left field
woodwright's Avatar
Check out Al's Liner. Its more diy freindly, and they have a product you put down first that is a sound deadener.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 05-28-2011, 01:40 AM   #7
masterlock
masterlock's Avatar
Here is mine, its actually Raptor Liner, it leaves a bit smoother finish, Im not sure but I think the Rhino liner is a bit rougher to the touch. It is also on the underside of the cab as well.
masterlock is offline   Reply With Quote
Old 05-28-2011, 02:07 AM   #8
TheApocalyptican
TheApocalyptican's Avatar
Don't have any pics, but I know a few guys who have done this.
Pros: Easy cleaning due to being able to hose it out & looks good(imo)
Cons: inside of the vehicle will be much hotter due to nothing really keeping the heat out. The heat problem is one that every guy I know who did it, isn't a big fan of. Depends how you intend on using the truck, and where you are located.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 05-28-2011, 07:28 AM   #9
tucsonjwt
I had rhino liner put on the floor of my 76 and would never do it again.
You will get extreme heat off the transmission hump and the underside of the floor from exhaust since you no longer have any floor insulation.
The texture of the rhino liner wears off and becomes slippery where your feet rub against the floor on the driver's side. The floor is also slippery when wet or has loose dirt. The dirt also discolors the rhino liner under your feet from constant in/out travel as you use the truck.
For the $240 I paid to have it done, I should have spent that money on good carpet, pad, Huskyliners, and Walmart treadmill mat over the hump and under the seat for protection. That is what I did to my current 83.
tucsonjwt is offline   Reply With Quote
Old 05-28-2011, 08:10 AM   #10
blackbeaSSt
i priced it for my 82 and it was outrageous even if i pulled the seat myself. also like was just posted and the guy told me, the heat will be extreme coming in the cab.
blackbeaSSt is offline   Reply With Quote
Old 05-28-2011, 09:31 AM   #11
rayfinseats
My plan is rhinoline the floor but not the hump and use heat shield insulation and rubber back boat carpet. (?)
rayfinseats is offline   Reply With Quote
Old 05-28-2011, 09:56 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
i was thinking for rust protection under the pad and rubber carpet
may just roll/brush rust paint if no real benifit
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-28-2011, 10:38 AM   #13
rayfinseats
I have had good luck with brush on rustolium. If you put it on thick and put it on quickly it will look just like it was sprayed. If you let it get tacky it starts getting brush strokes.
Old 05-28-2011, 10:54 AM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
yup me too did a floor one time took a week to dry but it was very cool in the fall
John
Old 05-28-2011, 07:25 PM   #15
hensonjd
What would be the best roll on liner to buy to use? And how thick can you put it on? Will the thicker you put it on just make it take longer to dry or will it cause problems?
Old 05-28-2011, 08:13 PM   #16
TheApocalyptican
To do it correctly....you wouldn't put it on thicker all at once. you would do it just as if you were painting, and do several coats to build up the thickness.
Old 05-28-2011, 10:00 PM   #17
hensonjd
Ok. I didnt know if you could put liner on top of each other. But that sounds like a better way to do it.
Old 05-28-2011, 10:15 PM   #18
Davidmichael
Davidmichael's Avatar
If you are going to run just the liner, then you will need some kind of mats for your feet. This stuff gets wore down quick and becomes slippery.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 05-29-2011, 10:35 PM   #19
xs-style
xs-style's Avatar
Mine wasnt rhino lined. I did the 3m sound deadener. Took 3 or 4 cans if I remember correctly to do the floor and the roof. Cost maybe 25 bucks and it helped quite a bit.
1978 Scottsdale - celebrating 10 years of teaching me profanity
1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold
1987 k5 blazer - sold... :\ seed money for the 81
1981 k20 4x4 - 5.3 swap in progress
Events attended:
Spring GOG 2011
Dale JR car show Summer 2012
Gathering at Tommys pickup parts
xs-style is offline   Reply With Quote
Old 05-30-2011, 12:33 AM   #20
sledhead61
I have a 87 short box. I stripped the cab during my build and sprayed rocker guard after cleaning all the rust and loose paint. I plan on putting carpet back down but though it was better to have a rubberized bearer between the moisture and bare steel. I personally don't know of any cons yet and think it turned out very nice actually.
I would recommend it!
sledhead61 is offline   Reply With Quote
Old 05-30-2011, 10:36 AM   #21
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I did mine in Rhino this last winter after a NV4500 trans swap. I love it! You can’t just run the Rhino alone as the cab will be hot/cold and noisy. I added Dynamat, insulation and a rubber floor mat over the Rhino. It is as quite as a Cadillac now. The main reason I wanted the floor Rhino’d is because I do a lot of off-roading and didn’t want water soaking into the floor boards causing rust again.
DirtyLarry is offline   Reply With Quote
Old 05-30-2011, 11:29 AM   #22
tucsonjwt
Floor mats over rhino liner won't work - rhino liner is too slippery for the mats to stay in one place. So, you need to cover the rhino linered floor with something, then install floor mats. So, why bother with rhino liner if you are going to cover it anyway? As long as you have Huskyliners which will contain water and dirt and cover all other exposed areas with vinyl you have a durable floor. If you have rust - fix the rust and spray it with something like rustoleum as described above. Just my $.02
Old 05-30-2011, 12:13 PM   #23
bodyworks
bodyworks's Avatar
Bedliner won't prevent rust, the expoxy sealer does that. Think of bedliner as a protective coating for what is under it. I have done frames, gas tanks insides of vehicles and many lower sections of pick-ups with it for stone chip protection. Works well but it is just a protective coating not a sealer from the elements. Hope this helps.
bodyworks is offline   Reply With Quote
Old 05-30-2011, 06:42 PM   #24
DirtyLarry
DirtyLarry's Avatar
A clean rust free interior floor that has been sprayed with bed liner WILL prevent rust from forming. If water from your shoes cannot soak and fester between the carpet and metal floor how can rust form? Will it stop the rust from forming on the roadside of the floor….No (unless the roadside was lined too). The fix for that is to not drive in road salt or move somewhere that doesn’t use road salt like the great Southwest.
Old 05-31-2011, 01:42 PM   #25
hensonjd
so why would multiple layers of rhino liner be aa bad idea if you were doing it yourself? Would that give you the insulation and also be durable. Im just trying to stay away from carpet and having to pay somebody to do it for me. What you think?
