Dominator air bags
Just looking to purchase my air bags and was wondering if anyone can reccomend dominator bags,
Chevy Only Tx
Re: Dominator air bags
They are descent bags. Some say they are a smooth ride. What I can tell the 2600's balloon up. They have alot of lift compared to other bags & not as pricey as other bags. I bought mine through eBay new 2-2600's and 2-2500's. I paid like 160 or 180 for 4.
Chevy Only Tx......... |
Thanks for the reply, i have been trying to find out the aired out width dimensions, but no luck
Nothing to see here.....
![]() Join Date: Jun 2007
they stay around 8" aired out. just a guesstamate, aired up is 7.5" od.
I like doms. I've used them on all the vehicles I've dropped.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
I have them on my '67 C-10, Dom 2600 front and rear with no problems but these being 8in dia they take work in the front. I also lay rocker and air up to stock height.
My '95 GMC lays rocker on Slam 2600, and the rides just fine but they only inflate to 11.5 and the Doms 13in and are .3in lower compressed. Both are great bags but he Doms if you make the room, they are a massive bag! Posted via Mobile Device |
We have them and have KILLER DEALS!! p/m us
Justin |
We do not have them on out site but we post some info this morning for you to see once we open up today.Stay tune.
Justin Last edited by Scottshotrods; 05-31-2011 at 10:02 AM. Reason: fixed |
67-72 parts collector,…
![]() Join Date: Nov 2002
Looks like max diameter is 8".
http://www.hornblasters.com/products...2600lb-air-bag. Specifications Part Number: AB-D26 Ports: 1x 1/2 in NPT Female Max PSI: 600 Restrained Load Range: 349 - 3055 lb (158.3 - 138.57 Kg) Collapse Force: 80 lb (36.29 Kg) Min/Max Height: 2.8 in / 12.5 in (71.12 mm / 317.5 mm) Stroke: 9.7 in (246.3.8 mm) Max Diameter: 8 in (203.2 mm)
Is there anyone on here using these with stock controll arms,
Here's a set installed on Charlie's blazer.
I just noticed the inner tie rod is install backwards. Anyone heard from Charlie? (member 70k52wd) Last activity was Oct. 2010.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-31-2011 at 09:27 AM. |
