Old 05-29-2011, 08:13 AM   #1
Chevypoor
Chevypoor's Avatar
Help! Master Cylinder Leaking
Our 69c10 has a manual brake master cylinder that is leaking down the firewall! It was replaced less than 2 years ago. It will also sometimes leak around the cover.
The master cylinder that was on the truck when we got it appeared to be doing the same thing.
The truck still stops fine.
Is this a common problem with manual brakes? Hopefully someone here has an answer as this is making a mess of things.
1990 S10 Reg. cab 2wd 2.5/ 700r4, lowered, soon to be a TBI 350/ 700r4
1993 2500 Reg. cab 4wd 6.5 turbo diesel/ 5spd, bigger turbo, Bull Moose pump, cold air intake, and a few other mods
1969 C10 Reg. cab 2wd 305/350, RHS heads, Voodoo Cam, Gilmer drive, 2400 stall, and lots of other goodies!
Chevypoor is offline   Reply With Quote
Old 05-29-2011, 08:29 AM   #2
cdowns
cdowns's Avatar
Re: Help! Master Cylinder Leaking
a good master cylinder does not leak
Old 05-29-2011, 09:14 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
If it is leaking around the cover, double check the seal between the lid and the master cylinder for tears, installed incorrectly/upside down, etc. If it is leaking from underneath the cover, it is probably leaking down the firewall when you accelerate and the fluid sloshes backward.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-29-2011, 10:17 AM   #4
SCOTI
SCOTI's Avatar
Along w/inspecting the under-cover (lid) seal quality, the fluid level should also not be exceedingly high.
It's common when pads/shoes get worn that the pistons extend farther out to compensate & the fluid level drops. People tend to add more fluid & then once the system is serviced there's more fluid volume than needed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-29-2011, 01:13 PM   #5
Chevypoor
Chevypoor's Avatar
It is leaking around the cover but also at the back where it bolts to the firewall. When you open the cover the fluid is about a 1/4" from the top of the resevoir. There is no evidence of any brake fluid on the "cab" side of the firewall.
Old 05-29-2011, 01:58 PM   #6
SCOTI
SCOTI's Avatar
The hydraulics are all contained in the engine compartment/underhood so if there's evidence of brake fluid leaking (wrinkled paint is the dead give-away if it's not wet) it has to be from the unit or the lines.
I would inspect the lines & fittings around the master cyl carefully since the prob continues despite using a diff master cylinder.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-29-2011, 06:36 PM   #7
Chevypoor
Chevypoor's Avatar
Thanks guys, I double checked everything again and it appears to be leaking from around the cover. Any thoughts on how to get a tighter seal? Can I adjust the bale? Or can I get a new seal or cover?
