6 lug to 5 on 4 3/4 conversion
I'm sure its here somewhere but what is the easiest/cheapest way to do front disc,rear drum 6 lug to 5 on 4 3/4 swap. Axles will be from Mark Williams so that part is covered. Can I stay with the manual brakes? I'm afraid my cam won't make enough vacuume and wanted to keep the firewall simple with no brake booster. Thanks!
04 GMC CCSB SLT Duramax 78 Chevy 3500 454 68 Chevy C-10 98 Arctic Cat 1050cc 9.66/135 1/4 mile asphalt |
Re: 6 lug to 5 on 4 3/4 conversion
i have chevy truck drop disc brake spindles....i use d52 wilwood calipers and slid on a 2nd gen camaro rotor......tada....done....a bit of a a guessing game fora while but i got it taken care of for the most part now.
o.......use 73-87 light duty spindles.....
Not Mine But A beauty
you can use something to make enough vaccum if cant cuz of the cam i forgot what its called tho
68 Chevy Shortbed 454/400 2000 Chevrolet Camaro SS 6spd 2011 Silverado 5.3 6spd auto |
Electric vacuum pump. They also have 'cam cans' which were basically large volume vacuum reserviors (check Summit or Jegs).
I dont want power brakes unless absolutly nessesary. I want to keep this build as simple as possible. More often than not less is more.
