05-30-2011, 04:20 PM | #1 |
Grandpa in the rustmobile...
Video of spinning my front left wheel off the ground..
http://s289.photobucket.com/albums/l...0530111225.mp4
I hope the link works. Trucks jacked up, shouldnt the tire spin more 'freely' than this? New soft lines, new hard lines, new 71 MC for disc drum new booster etc etc new calipers Im stumped.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-30-2011, 04:33 PM | #2 |
Re: Video of spinning my front left wheel off the ground..
Doesn't seem to extreme to me. Drive it, check it to see if it gets hot.
05-30-2011, 04:38 PM | #3 |
Does it seem like they are dragging? I only have about 25000 miles on the truck since I bought it (droev it awhile before I went disc).
Im on my 2nd pair of rotors and these ones are grooved really bad.
05-30-2011, 05:14 PM | #4 |
The One And Only !!!
Looks like a little too much drag to me, How many miles did you get out of your first set of rotors ?
Have you tried cracking the bleeder and see if it frees up ? Compressed the caliper with a C-clamp and see if it frees up ? Any chance you have the bearings adjusted a little too tight ? How did you convert to disc, A aftermarket kit or OEM parts from a newer truck ? Sorry for all the Q's.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
05-31-2011, 01:09 PM | #5 |
New parts/and parts from autozone etc etc etc (autozone, advance, orielly etc).
The bearings COULD be too tight, but I can hear it screech past the pads every rotation. I'll crack the bleeder next chance I get and see what happens.
05-31-2011, 03:46 PM | #6 |
somebody remind me but doesnt the drum brake porportioning valve keep some residual pressure in the line? did you change this at the time you did your swap?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
05-31-2011, 08:26 PM | #7 |
Its a relatively new brass disc/drum prop. valve.
Maybe its not bled corrrectly or enough? Ive replaced parts so many times its not funny.
06-01-2011, 11:57 PM | #8 |
BMW & ASE Master Certified
If I were you i would take the wheel off and take the brake caliper off. spin the rotor... does it spin easily or does it drag and stop like in the video.. if it drags like in the video, you probally overtightened the center bearings. What can cause excessive wear on the bearings and spindle.
If it spins freely put the caliper back on and press the brake to get the pads close to the rotor... does it stop like in the video? if so your caliper might be sticking or maybe the pads are incorrect like they are to thick or something. start with the basics or start replacing random parts for no reason... clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
06-02-2011, 02:17 PM | #9 |
If I recall correctly, it spins freely with the caliper off. I REALLY wanna try to make some time to work on this. Im doin hay today its hot and im tired.
You guys can walk me thru all of this I just gotta get out there. thanks!
06-09-2011, 09:09 PM | #10 |
Stripped bleeder, broke the front line just below the prop valve to let fluid out. Still tight. Separated MC and booster and nothing. Squeezed the caliper and it spun freely.
Its NOT an over tightened wheel bearing nut. Maybe the wrong brake pads or something? Also, the inside of the rotor is grooved alot, the outside isnt, what the heck is going on? thank you
06-09-2011, 10:27 PM | #11 |
67-72 parts collector,…
Sounds like a bad caliper.
06-09-2011, 11:13 PM | #12 |
thats whats it sounds like ^^^^^^^^
06-09-2011, 11:25 PM | #13 |
But ive replaced calipers multiple times, both sides?!
06-09-2011, 11:36 PM | #14 |
u rebleed the whole system right is there a new master in there
06-09-2011, 11:49 PM | #15 |
New MC for like the 2nd time. (really tierd of buying parts that dont help anything.)
Im going to re bleed in the near future and go from there. Problem is my FL bleeder screw is stripped (tried standard then metric then I was like heck i'll just bust it loose with some vice grips real quick...... ) Now its stripped all to h$%*!!! Cheap friggin' metal is what it was made of!
06-10-2011, 01:25 AM | #16 |
maybe a pinched line take the nipple off both side up front see if one leaks more than the other one
06-10-2011, 01:35 AM | #17 |
I have also seen a stopped up hose do this. Causing the caliper to stay compressed somewhat it wouldnt let all the pressure back off when you let go of the brakes. Once I replaced the hose it freed up.
06-10-2011, 01:59 AM | #18 |
Second Chance Program
MAybe im high but i think thats pretty normal.
06-10-2011, 07:38 AM | #19 |
Senior Car Nut
well, it's hard to tell from the video but I'm with lakeroadster and y5mgisi (if indeed y5mgisi is referring to the video and not his state of mind) on this. it's my understanding (quite possibly wrong) that disc brakes don't "retract" like drum shoes do. they release pressure, yes (if your's weren't, you wouldn't be able to move the wheel) but they don't pull away, instead relying on the small wheel wobble to create clearance.
my guess is that when the new pads wear into the grooves in the rotor it'll free up more. is the bleed screw pointing down or up?
Larry Last edited by fleetsidelarry; 06-10-2011 at 07:58 AM. |
06-10-2011, 11:09 AM | #20 |
I think it should've 'worn in' by now. I drive it everyday and did the converison 2 years ago..
06-10-2011, 11:10 AM | #21 |
new braided hoses from ECE too
06-10-2011, 12:32 PM | #22 |
Is the caliper sliding freely on the bolts or could it be freezing up?
06-10-2011, 12:36 PM | #23 |
What do you mean WORP67?
Ive had it on off quite a few times...still the same. It seeemed to get better when I bleed my brakes and put a new MC on... (6 months ago, same problem)
06-10-2011, 01:14 PM | #24 |
I am not sure which calipers you used but some have bolts that slide into the caliper bracket and others have studs on the caliper bracket that the caliper slides on. If those get dry the caliper can seize on them. Causing the caliper to stick and can cause this.
Also did you use the 1" or the 1 1/4" rotors? did they give you the correct pads and calipers to match the thickness of the rotors? Some of the swap guides mention both thicknesses of rotors. How much heat it coming from it when you stop? Does the other side do this or does it spin freely? Last edited by WORP67; 06-10-2011 at 01:15 PM. |
06-10-2011, 02:48 PM | #25 |
I wanted to check both sides out last nite but didnt have room on the other side so I said forget it and went inside.
I believe I have the 1.25" rotors, I assume I have the right pads/rotors combo... I guess I could take them back 'under warranty'? (Lifetime I think). Im using 1971-1972 calipers (I cant remember which year exactly). Caliper bracket?...Im using 71 72 stock spindles..
