Turn signal?
After installing a 4 spoke chevy wheel my hand hits the turn signal arm{flat wheel,no dish}when steering.I would like to reverse the arm and maybe even tweek it alittle,how is it attatched to the column?Thanks.
Re: Turn signal?
It fits into a slot in the mechanism and is held in place with a single screw. Should be able to flip it.
Re: Turn signal?
Thanks.
![]() Join Date: Sep 2010
Re: Turn signal?
I had the same problem with mine but I didn't think of flipping it. I took it off, heated it with a torch and carefully bent it to the angle I wanted. Worked like a charm.
its all about the +6 inches
Re: Turn signal?
if you flip it, it'll probably be too far forward. I've bent many of them with no heat.
Cruzin
Re: Turn signal?
very simple to bend just put flat part in a vise and it will move easily
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Re: Turn signal?
