Gas tank bracket removal
What is the preferred method to take the old inside gas tank brackets out? I could just cut off the lower portion and leave the spot welded section in, but would rather not. Do I need one of those spot welder drill bits???
Thanks. |
Re: Gas tank bracket removal
i just cut the nose off and left the bracket. It seems kinda structural to me. If not then drill the spot welds and hammer away. Also i think the one bolt that is left holds the cab support brace. might want to brace that up...good luck
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726 ![]() 66 fleet lwb- In process 64 k10 10inch lift 38.5's- In process 92k1500 400hp on 38.5-parts truck now 8( |
This is what I did
Removed the excess part of the bracket Cleaned up and scribed a line in the front part of the bracket Folded the front part of the bracket up Welded up and ground down
Ken B ![]() 60 Chevy Apache 2019 Chevy Silverado Z71 Why buy something when you can build it for twice the price.. ![]() Just because something can be done doesn't mean it should be done... |
i cut the spotwelds and removed the whole bracket. go slow so you don't drill all the way through the back of the cab. don't ask...
Jason Garverick 64 C10 SWB Stepside 350/muncie - 5.3 vortec (soon)Thread 69 AMC Javelin 360/auto - 417 stroker (soon) 68 Scout (Basketcase) 06 Ram HEMI SWB Reg Cab Daily Driver US Army Vet |
I did something similar to mailman
1966 GMC Extended cab 1 1/4 ton 4x4 My build thread 1958 Chevy 1 ton dually flatbed My Dad's build thread 1966 GMC Custom Trim Big Back Window W/351e My Time-Killing Project Truck 1966 (Not So) All Original Chevy Custom Trim Suburban My Dad's Time-Killing Project Truck |
Custom Builder
![]() Join Date: Jun 2003
We just did this to our Big Window Cab. We used the spot weld tool from Snap-On/Blue Point and it worked great. The trick as I learned was to use a small wood wedge behind the panel. This is to put just enough pressure so that as soon the weld is cut it will pop out. Just take your time as there are about 14 spot welds holding each one in. I only went through the cab on one weld, that is when I figured out the wood wedge trick. If you go through the cab save the plug to weld back in.
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 Last edited by LeftCoast32; 06-05-2011 at 10:30 PM. |
I used a cut-off wheel, good enough for my ole shop truck!
You Guys are awsome
![]() Thanks very much. |
