06-09-2011, 07:08 AM | #1 |
Its a Truck Thing......
Serpentine Conversion Help
Guys and Gals,
I am about to do the serpentine conversion on my 71 350 and the final step is the radiator hoses. I know there are a few of you that have sucessfully completed this task and I am asking for some assistance. What upper and lower hoses did you use? I am kinda pressed for time and dont really need to make a million trips to the parts store to see if they have something that fits. I tried the upper hose last nite and its off of a 92 GMC and the diameter is too small. So if anyone has this information and would like to share please help me out. I went through alot of the topics last nite and only one post had a top hose part number which online is no good anymore. I go out of my way for alot of members to get pics and research alot and now I need someone to do that for me...... If this doesnt work I guess Ill PM a bunch of people and see if they return it. Thanks, Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
06-09-2011, 08:52 AM | #2 |
Re: Serpentine Conversion Help
If you go to your parts store order the upper and lower hose for a mid 90's GMC truck that came with serp brackets. small block. 96 GMC 4 WD 350 truck should work. The upper hose can be difficult and has to be rather long to reach. A swivel thermo housing can make it a bit easier to deal with. The lower hose is a fight regardless but a few cold ones and some common sense will get it installed.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
06-09-2011, 09:11 AM | #3 |
The Few, The Proud
Try these threads. Granted they are referring to 4x's, but that shouldn't make a difference. On the bottom one grab a Gates 20842. I have it mounted already on my setup so I know it works for sure.
Upper hose XL 1171 http://67-72chevytrucks.com/vboard/s...d.php?t=346154 Lower hose Gates 20842 http://67-72chevytrucks.com/vboard/s...d.php?t=464850
Shannon |
06-09-2011, 11:55 AM | #4 |
Thanks Guys,
I pulled the 1171 and 20842 plus a few more numbers out of 3 pages of threads, re-ran the 1171 without the XL and found it. Sammy, I would have to recheck on the mid 90's stuff, I got a hose from a 92 and the radiator diameter was way too small. It would be nice to just go there and get one trips worth of parts without having to do it many times....I am trying to do this conversion and move and get my AC fixed...... I will list all the parts that i got for the next guys so people dont have to guess. Thanks Again Smitty
06-09-2011, 12:03 PM | #5 |
go cyclones
If you have trouble finding a hose that works. Get a piece of wire and model the length and shape of the hose you would need. Get the hose ID which would be the OD on the water pump and radiator. Armed with this information go to your local parts counter and try to find a hose that matches your criteria. If anything it will save you from getting the wrong part.
06-09-2011, 07:05 PM | #6 |
Sdailey,
Do you remember what year pump you put on? I bought a pump off the engine I pulled the brackets off of and its the same pump for the v8. Thanks, Smitty
06-09-2011, 10:44 PM | #7 | |
The Few, The Proud
Smitty, I bought my serpentine setup as a kit. The part number for the water pump is 88894005 (Water pump kit). Search part number 12497698 through the link below and it'll show all the part numbers for the kit. Hope this helps. http://www.gmpartsdirect.com/
Shannon |
06-09-2011, 10:09 PM | #8 |
I'm doing the same conversion but have not gotten to the hoses yet. I have used 1996 chevy k1500 for all parts like water pump, power steering pump, idler, alt, etc. I'll be watching this for hoses.
Forum member Johnoro just got done with this. Maybe he'll give up the hoses he used. I think I will see him this weekend and will post the part numbers he used if I can get them. Posted via Mobile Device
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 06-10-2011 at 10:57 AM. Reason: typo |
06-10-2011, 07:27 AM | #9 |
Shannon,
Thanks brother, the water pump number crosses over to the one I bought. Just got to play with the lower hose and get it to get on there.... Smitty
06-10-2011, 09:02 AM | #10 | |
The Few, The Proud
No problem at all. Glad to help out. Be sure to post pictures.
Shannon |
06-12-2011, 01:35 PM | #11 |
Update coming later today. I have it finished and its pretty sweet....Pics coming too along with a total parts list that will work.
Smitty
06-12-2011, 08:01 PM | #12 |
I know I said pics, but after I broke pushrod (my own fault) the pics wouldn't be pretty, so tomorrow after I fix the pushrod pics are coming. Here is my parts list that completed my serpentine set up. This was pretty easy and I found a new way to use my old lower radiator hose with the help of a 24 inch cresent wrench, so the lower hose in no issue. i bent the frame down just a tiny bit and the old hose fit perfect......My brackets/pulleys came off a 95 chevy blazer and it had no smog pump. Just make sure if you go to a junk yard take a power steering pulley remover or you wont get the bracket off without destroying the old pump. There is a bolt back behind the pump on the head there you need to get to.
1. Power steering hose. I picked up a 70911 from advance auto for a 75 chevy c10 and it fit perfect, just use the hose fitting bolt out of your old pump. 2. Water pump came off a 95 blazer from autozone CWP-715. 3. Power steering pump, 95 blazer from advance SP17094. 4. Alternator (most expensive part) from autozone 92 GMC DLG1345-6-7. 5. My truck has guages so i need the adapter harness with the resistor in it, got it from rock auto S792. Then jumped the regulator. 6. Thermostat gasket for 92 GMC from autozone 35062. 7. AC bypass pulley (for now) 95 blazer, rock auto 34152. 8. Thermostat housing 92 GMC from rock auto 10147884. 9. Gates belt 95 blazer rock auto, K060956. 10. Idler pulley, 95 blazer rock auto, 19190148. 11. Tensioner, 95 blazer rock auto, 88909598. 12. Upper radiator hose, had to modify to fit autozone, 1171. 13. 3/4 heater hose 4ft. I have an ac truck. I bought alot of AC Delco parts and had my brackets and pulley's powdercoated, but you could do this pretty cheap if you bought part store parts and painted it your self. I didnt drill in my head for one bolt, but I have the bracket that bolted to the water pump, so everything is pretty strong. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" Last edited by 71meangreenc10; 06-12-2011 at 08:03 PM. |
07-11-2011, 02:03 PM | #13 | |
72 C20 Longbed 05 1500 Z71 |
10-02-2021, 02:37 PM | #14 |
Ok, so we’re doing this conversion right now and trying to find a bracket because we’re not gonna drill the head. I know this was a long time ago, but do you remember where you got that bracket coming off the water pump?
10-02-2021, 08:33 PM | #15 |
I called Vintage Air when I added A/C to an early 350 that I put a 80's era serpentine system on. They said no problem sent me the parts. They sent some adapter brackets to convert my serpentine setup from an R4 to Sanden.
So in short its worth a call and talk with them directly. I'm sure you are not the first one to do this with one of their kits.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
10-02-2021, 08:57 PM | #16 | |
Smitty
10-03-2021, 07:17 PM | #17 |
10-03-2021, 08:47 PM | #18 | |
Smitty
08-12-2011, 08:28 PM | #19 |
Here are the pics,
The first one is what I started with, then the new parts started showing up. Then I had everything in place and finally AC was completed. It was 90 here today and 40 inside the cab (I have a thermometer in the vent) 38 this evening..... Love it... Smitty
08-12-2011, 08:29 PM | #20 |
Last pic.
Everything works with the factory controls. Found an evaporator that fit the box so I didnt have to mod it. Smitty
08-12-2011, 11:23 PM | #21 |
ttt for z bookmark
08-13-2011, 01:24 AM | #22 |
Looks great Smitty, good job ! What yr. truck is that upper radiator hose from ?
08-13-2011, 09:34 AM | #23 | |
Dont know the year, I went to autozone and got a 1171 and trimmed it down to fit. Smitty
08-21-2011, 08:52 PM | #24 |
What is the lower hose from?
1970 C10 SWB, 67 front clip, 3/5 drop, 350 TPI/700R4, Fiberglass tonneau cover, lots of body mods and.....a ford seat |
08-21-2011, 10:42 PM | #25 |
Used the original hose, just bent the lip up a little and put in a piece of hose and its fine.
Smitty
