Old 06-09-2011, 08:58 AM   #1
CVA59
Cab Swap????
Will a 61 cab fit onto a 64 frame without modifications?
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 06-09-2011, 09:29 AM   #2
Clyde65
Clyde65's Avatar
Re: Cab Swap????
I dont think so, the 60-61 frames are wider than the 63-66 frames. I would measure to verify
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-09-2011, 09:37 AM   #3
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: Cab Swap????
Front cab supports are spaced differently,rears are the same.
Also has the twin holes in the firewall,but a conversion bracket is avialable from CaptainFab to run a newer pb booster.
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 06-09-2011, 10:18 AM   #4
CVA59
Re: Cab Swap????
Thanks guys. I was thinking of swapping over from my 64 sheet metal to a 61 like my Grandfather had. I have done too much work on my frame to change all that over too. I will just stay with what i have, LOL.
Zack
www.23t.weebly.com
Old 06-09-2011, 11:40 PM   #5
Captainfab
60-66 Nut
Re: Cab Swap????
You don't have to change anything on the frame. To install a '60-'62 cab onto a '63-'66 frame all you need to do is drill a new hole in the floor of the cab farther inboard to line up with the frame bracket.
Old 06-10-2011, 08:39 AM   #6
CVA59
Re: Cab Swap????
Wow, in that case i may keeping looking into it. That seems like a pretty mod. Thanks Fab.
Zack
www.23t.weebly.com
Old 06-10-2011, 09:51 AM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Cab Swap????
here is a thread that has some pics:
http://www.67-72chevytrucks.com/vboa...d.php?t=355711
Old 06-10-2011, 11:42 AM   #8
CVA59
Re: Cab Swap????
AWESOME!! Thanks for the link. That is exactly what i am looking for. i called myself searching but apparently i didn't do a very good job, LOL.
Zack
www.23t.weebly.com
