Old 06-09-2011, 06:44 PM   #1
kenm78
Broken Down
kenm78's Avatar
82 Chevy K10 Ignition Switch
Do I need to remove my steering column completely out of the truck to replace the ignition switch that is mounted on the top side of the column? I see a little rod going along the top that moves when I turn the key I am assuming that connects to the switch mounted on the coloumn?
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 06-09-2011, 08:29 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 82 Chevy K10 Ignition Switch
ive never moved the column to get one out of a 2wd truck the columns interchange so i doubt youll have to a combination wrench should work just fine
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-10-2011, 11:06 AM   #3
TDS-MN
It can be removed and replaced with the column in-place. You may want to partially drop the column from the dash, to allow a LITTLE bit better access for reaching in there to work, though. There are 3 different size nuts I needed to remove on my '85 to get the ignition switch out and replaced, it is tedious work, and hard to see what you are working on when it's under the dash like that.
Yes, the rod is actualted by the key switch in the column, and sldes from ACCESSORY to OFF to RUN to START. It is critical to get the switch in the proper position related to where the key and rod are when installing. But at least if you get all the mounting screws lined up 100% corectly, it should go back together and work just fine. Don't think that 'close enough' will work, because if not lined up perfectly, things won't work properly. Take your time and be sure of your work.
I swapped out my ignition switch when I was trying to track down a no-voltage no-start problem. Advice I got on the various forums was to check wiring, as the switch itself is NOT a high failure-rate part. I probed with my voltmeter and results were pointing towards a bad switch. But in the ned it turned out to be a wire on my engine-side of the fire wall, had corroded and broken off the junction block near the brake master cylinder. But on the positive side, I got to where I could remove and replace the ignition switch fairly quickly, after doing it over and over a few times before finding the broken wire under-hood. LOL!
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
