Life, Be In It.....
![]() Join Date: Oct 2003
How far can the tweeters be from the mids
I was thinking of putting these in the truck. The MIDS in the doors and the and TWEETERS in the door pilars or head linger. Will that be ok or should they be closer together.
I thought about just doing a COAXIAL version of this speaker, but was worried that I wouldnt hear the tweeters. Orion® XTR62 6.5-Inch 2-Way Component System Product # XTR62 Power (Peak / RMS) 120 Watts / 60 Watts Nominal Impedence 4 ohm Frequency Response 75Hz - 22KHz Depth (Inches) 2
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
Re: How far can the tweeters be from the mids
they should be as close as possible for best imaging and sound. Ideally coaxes are the best arrangement, however few companies put their best speakers in this arrangement. Great distances between the two can also lead to phasing problems and other sonic nuances.
As a practical matter if you don't care about staging, imaging and all that, put them where you want. The casual listening probably won't notice the difference if they don't know what the are listening for. As a geewiz, FYI, kickpanel placement is very popular for imaging in pro audio cars as it gives the most equal distance possible between left and right sides. Using the balance knob isn't quite the same thing ![]()
Project Bad Karma Last edited by pockets; 06-10-2011 at 10:11 PM. |
#3 | |
Life, Be In It.....
Thanks, well I guess I just get the Coaxial version Orion® XTR602 6-Inch 2-Way Coaxial Speaker Model Number XTR602 Power (Peak / RMS) 100 Watts / 50 Watts Frequency Response 85Hz - 22KHz Sensitivity 86dB Depth (Inches) 1.75
#4 | |
The Engine Whisperer
to the OP. With a good coax set you should be able to hear the tweeter. And orion is a great company. The component set actually has a higher sensitivity rating, so thats what I would choose. Just mount your tweeter in your door. I'm not sure if they're clockable tweeters, but if they are, just mount them up and to the front of the speaker and clock them up towards the driver
-Automatics win races, 6-speeds impress high school kids -Save a tree, support your local dragstrip. -"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui columbuscarsandcoffee.net and on Facebook Last edited by ProStreet68SB; 06-11-2011 at 01:41 AM. |
I've read a lot of professional articles that would disagree with you. Ideally sound should come from two points, left and right. deviation from that, i.e. two axis from a single side can muddle the sound. In practice it doesn't happen all that often, but if separating them was the best route people wouldn't put them close together. Bass is an exception because it is omnidirectional, especially in a car.
There have been high quality coaxes made and in those the manufacturer takes a component set and mounts the tweeter over the midrange driver. High quality coaxes are harder to manufacture than high quality components, so they are rare. And if you care about imaging, you don't aim the speakers at the driver, you aim it towards the center of the vehicle, such as the dome light or even at the opposite seat (driver side speakers pointing towards the passenger, and vice-versa)
Project Bad Karma |
#6 | |
Now 2 judge format is harder, you essentially have two sound stages, one for each side. (judge in driver seat and judge in passenger seat) Then you must blend in the middle for the best overall score. This past years winner basically took a Tube chassis car with a stock car body on it, and shoved the seat as far back and as close to the middle as he could. |
78K & 79C Jimmys
i cut the tweeters out of a pioneer set
made small boxes to aim them as i couldn't here them to well don't need as much power to hear the high as the lows
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#8 | |
Tasty Cakes!
As you noted though, most people will never notice the difference. ![]() With all that said, if you're going to mount your speakers in the doors, MOST people will be happier with separates. Mids low in the doors and tweets by the window crank or even in the A-pillars. My $.02
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
My mid is in the vent hole and my tweet is the lump above the window crank in the door panel. They sound very good there. I was going to put the tweet in the kick panels, too but didn't like the sound.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
I am still thinking of adding a 4" in the bottom of the door, but I haven't gotten that far.
I'd do the seperates, coax are a compromise.. at best..
highs radate in a straight line and the reason for "dome" tweeters you want them aiming at the ears, within reason, the pro's make it happen, you don't need to spend weeks building a mount to place it in the truck.. in a standard cab truck you really can't get the tweeter far enough away from the mids to have an issue.. you'd have to put the mid driver in the kick and the tweeter behind your head to have a timing issue.. your truck I'd put the mids in the kicks and the tweeters in the upper door.(as that panel is replaceble if needed. kick panels that aim the speakers at you, then put both in the kicks.. tweeters don't like dirt.. so I don't like mounting them that low.. my truck was already cut so there is 6by9's in the rear of the door, 6.5's in the front of the door, 6.5" in the kick panels and the matching tweeter in the dash(beside the a/c vents) once the tank is out of cab.. a single 12" sub will go back there and move the 6 by 9's to back there.. looks like you have no issue cutting (see dash) if you put the speakers in the doors, you may chase rattles.. and get the foam speaker backers to keep them dry ![]() |
#12 | |
I will probably not go this high tech but just thought I would ask.
1. Tweeters can be very small, why can we not place them above the door toward the front of the vehicle 1 aimed at the driver the other at the passenger. alternative: I have a 66 gmc and I have room on the dash to put a small tweeter facing the passenger and the driver, Then I could place 1 speaker in the center of the dash facing upward that has 2 mid ranges pointed toward the rider and passenger. Then a mono sub behind the seat . ?? Would this work or am I creating more problems than I am elimanating. ps I am not look for a competition system just good sound. Thanks Kieth Here is a pictu re of the dash drvr side http://kieth.smugmug.com/Trucks/66-G...738746_6RPBQ7f pass side http://kieth.smugmug.com/Trucks/66-G...8_prjBSsx-A-LB |
#14 | |
78K & 79C Jimmys
myself i always prefer left and right subs for seperate hits, if it's not for comp try working it with a left and right rear box, ported up by the belts?,for lots of feel i use small project boxes to hold tweeters (for staging/testing but they went unnoticed so i keep using them) and you use two sided tape to move the tweets till you "got it" i'll go see if i can find some...
#15 |
1. i was thinking of 2 tweeters either in the dash or up above the door sill . (could be pointed without interferance) 20 watts rms
2 mids, in the dash where the old single speaker usually went 50 watts rms 3. 1 sub in the back ?? 150 watts rms ? will it sound ok at normal listening levels? |
