06-12-2011, 07:54 PM | #1 |
Converting to electric fans
I'm looking to convert to electric cooling fans, what with the ridiculous Texas heat and all. Can anybody give me any advice as to which fan I ought to go with? I'm running a fairly stock 350 with headers, no a/c, with an external transmission cooler. I'm seeing a whole lot of different products and prices. I wanna keep it as cheap as I can cause I'm poor, but I don't wanna buy some hunk of crap that won't work. Thanks in advance for the help.
06-12-2011, 08:08 PM | #2 |
Its a Truck Thing......
Re: Converting to electric fans
I have the jeep mod fan in mine, fan was less than 50 bucks, fits in the shroud perfect with a little help, I did buy a better fan control unit from jegs, it was $99 and has adjustable contols.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
06-12-2011, 09:22 PM | #3 |
Is your ride over heating? Not trying talk you out of fans but if you don't have a lot of money don't spend it on fans. A properly working stock system will keep your ride as cool as fans.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-13-2011, 12:14 AM | #4 |
What sized radiator do you have in the truck? you might start there for your cooling issues. I have the jeep fan conversion in my truck. Also a 4 row radiator new water pump, good hoses, and vintage air ac. I had been tracking down a heating issue that turned out to be a bad gage.
Cross reference heating issues with a infrared thermometer to make sure its not a bad gage before throwing money into it.
1970 GMC truck 1988 Harley 1200 Sportster |
06-13-2011, 01:49 PM | #5 |
Where can I find a thread or an article about the jeep conversion? I haven't heard about it.
06-13-2011, 04:08 PM | #6 |
http://67-72chevytrucks.com/vboard/s...d.php?t=458218
The original is in the faqs section
06-13-2011, 06:16 PM | #7 |
Not trying to Hiest the thread but what are the benefits of an electric fan over stock? Is it just the constant speed of the electric fan or the reduced drag on the engine from the stock fan? Is there an increase in power without the stock fan?
Posted via Mobile Device |
06-13-2011, 06:20 PM | #8 | |
06-13-2011, 06:29 PM | #9 | |
06-13-2011, 06:49 PM | #10 |
i don't know if you can feel it a LOT, but to me there was a difference especially towing or using cruise control on bigger hills.
06-13-2011, 09:29 PM | #11 |
Average HP increase with electric fans is 10-15hp. It takes at least 25hp to feel in the seat of the pants. As far as mileage, unless you track it regularly, you'll never notice the difference. Electric fans are a nice upgrade but don't expect to notice higher HP or to recoup the the cost with higher mileage. Also don't do it to lower the operating temp, find the real problem and correct it.
06-13-2011, 09:46 PM | #12 |
It was 102 today in Austin. How hot are you running in this heat? If I get stuck in stop-and-go traffic my temps easily reach 210. Once I get going I drop to 185. That's with aluminum radiator and twin 10" fans. I plan to swap out my 160 t-stat for a 195 to give the water a chance to cool.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
06-14-2011, 09:13 PM | #13 | |
Something else may be going on here. But to continue the fan discussion, the benefits of an electric fan have more to do with saving engine power when the engine doesn't need extra cooling. For example, when cruising there is enough ram air through the radiator to cool the coolant. With a belt driven fan engine power is always being used. A clutch helps with this by allowing the fan to "slip". But some power is still being used. If the fan were to be removed altogether the power used it gone. An electric fan does this by completely shutting off when air movement isn't needed. But when vehicle speed is too low to provide enough air flow the electric fans take over assuming the fan's thermostat is installed properly. |
06-14-2011, 09:53 PM | #14 |
Magma is right on! T-stat regulates when the engine starts going to the well to get a drink (I mean start cooling). Do you run a shroud or clutch fan? These would be questionable if things get hot when you stand still. The shroud funnels all the drawn air through the single point needed and the fan clutch...well if it aint engaging, you don't get air flow. Maybe a blockage or anything/ everything combined. Also check the accuracy of your gauge....mine misled me. Hope this helps.
06-13-2011, 09:49 PM | #15 |
~Rest In Peace~
pushing or pulling
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-14-2011, 12:28 AM | #16 |
I pushing or pulling better? Just bought a pulling dual 12" and dont really know the difference. I plan on using it as a pulling unit but might change is pushing is better.
06-14-2011, 09:59 PM | #17 |
On another note, just listen to the fan when you rev your engine. It pulls harder the faster the engine turns. When you free that up at highway speeds and the fact its generally only running (the electric fan) when stopped it saves some in fuel and HP.
Not to mention taking the somewhat unbalanced weight off the pump shaft which kills 'em. I'm gonna do it....hopefully soon! |
06-16-2011, 05:06 PM | #18 |
I'm running easily 210 in the heat. If I sit, I'm flirting with 220. My gauge could be wrong, as it is an after market installed by the previous owner. I just installed a new water pump (old one was leaking and the pump shaft bearing was worn as hell) but haven't noticed a difference in temp. Radiator isn't leaking, coolant is clean and full. Clutch fan, no shroud. The fan spins on the clutch with not much effort by hand, so I assume that it's in working order. I have a shroud, but the fan is too big, and I'm having a bit of trouble locating a replacement. I figured if there is an appreciable benefit for going electric I'd go with that. As far as the radiator, it appears to be stock.
06-16-2011, 05:40 PM | #19 | |
06-16-2011, 05:48 PM | #20 |
67cheby
AUStx68... have i missed your build thread ??? your interior is beautiful, i want to see more of the truck !!
06-16-2011, 05:53 PM | #21 | |
06-16-2011, 07:50 PM | #22 | |
Another problem would be the clutch will be "disconnected" in a thermal sense from the radiator. Consider a properly running engine and cooling system with all the original components in place: The clutch "feels" the heat coming off the radiator. As the radiator heats the air passing through it, the air heats the clutch which is designed to allow more torque from the pump shaft to spin the fan. As engine heat is reduced or vehicle speed increases and the fan isn't as necessary, the air passing through the radiator is cooler which means the clutch allows the fan to "slip". This reduces engine load which improves mileage and performance. My advice? If you want to keep it mostly stock, it may be easier to find out why the fan/shroud combo you have just won't work together. Is it the fan? The shroud? If you don't mind moving away from the stock look, the electric fan setup would work if the fan is sized right, meaning it covers the radiator properly and the flow (CFM) is correct for the cooling demand of your engine. I'm poor so I still have the stock setup, so I can't give recommendations as to the proper electric fan and CFM. Good luck! --Mike P.S. Missing the fan shroud would be kind of like having a broken duct in your furnace/air conditioner in the return line in the attic. |
06-16-2011, 08:24 PM | #23 |
I am remiss for not including the shroud/fan size problem to begin with, sorry about that everyone. That is essentially why I am looking to move to electric, as my fan is too big for the shroud, I know I need the shroud, and finding another fan has proved problematic. I have a mid 70's motor, not the original, and a junk yard correct year shroud, so I'm guessing the 1/2in or so difference in fan size can be attributed to the year. I'm not a stickler for stock appearances, so esthetically an electric fan would be fine. My truck is my daily driver and by no means a show vehicle. The jeep fan fix seems to be a good solution, cheap and readily available. Thanks for the help, guys. Oh, and Magma, I had no idea that lack of a shroud effected the clutch so much. I learn something new everyday.
06-17-2011, 11:59 AM | #24 |
foriamclever,
Don't worry, no big deal here on my end. I like to study/build electronic circuits. I mention this because over the years I've purchased books that explain electronics. The problem I've run into is that they assume more than a basic understanding of electronics which I once lacked. But I've found that a classroom text book is great at explaining not simply how something works, but why it works. See if you can find a classroom shop manual for a high school level automotive class. I have one from my high school from the early 90s. Of course, the book was published in the early 70s! I got it complete with graffiti! |
06-16-2011, 05:21 PM | #25 |
Oh, and thanks for the link to the cheap electric fan build, kevmic.
