06-13-2011, 12:52 PM | #1 |
Door wont unlock
I have 1982 Chevy Blazer with Power Locks, cant open it from the outside with a key, with the power lock switch or pulling up on the lock. Any suggestions?
2012 F150 SuperCrew 2011 GMC 1500 (COMPANY TRUCK) 1982 Chevy Blazer 2WD (Work in Progress) |
06-13-2011, 02:51 PM | #2 |
Getting Old; Going Broke
Re: Door wont unlock
Have you had it apart and put it back together or something? Sounds like the linkage is off or crossed or something. You can get the trim panel off with the door shut, which is what you'll need to accomplish. Then you'll be able to see in there and find out what the issue is.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
06-13-2011, 03:07 PM | #3 |
i just got it Friday and when i got it home it wouldnt unlock. I will take the panel off and check it out.
06-13-2011, 09:53 PM | #4 |
I had this very same issue on a '84 blazer on the passenger door. The problem is down in the actual latch mechanism where the lock rod raises and lowers this little lever in there. Its a huge pain in the butt. You have to get the door panel off and get down in there with something to pry it up. Let me tell you it can be tough!!!! i ended up using a small pry bar and it was all i could do to un-jam it. It is a finger smashing Bi*%$ too so be careful. After i got it open, i lubed it up good, but didn't help at all. It did the same thing again. Its something in there that is either out of alignment or bent.
1984 K10 SWB "Coal" 1987 K5 Blazer "Ole Miss" 1979 GMC Jimmy (Project) 2008 F250 CC 4x4 King Ranch 6" lift on 37's (Spartan-ized!!) 2008 Dodge Challenger SRT8 Hemi Orange 2008 HD StreetGlide 2007 HD Custom Fatboy 1980 Suburban (will be for sale or trade soon). |
06-14-2011, 07:41 PM | #5 | |
I know the pieces fit
