06-13-2011, 05:40 PM | #1 |
Tie rod ends and front end alignment
Last week I was looking for a noise coming out of my front end, I jacked up the front end and shook the crap out of everything, everything was tight and the only thing I could find that could be making the noise was the upper leaf spring bushing. Today I replaced the bushings and the noise it now gone but I found that both tie rod ends were VERY worn and very sloppy. I can't figure out how they could be so sloppy after just a few days!
Anyway, I ordered new ones, they will be here tomorrow and now I'm curious what I can do to keep the front end aligned when I replace the tie rod ends on my other truck I remember spinning the wheels while holding a piece of chalk against the tread, drawing a line all the way around then measuring the line, making sure I end up with the same measurements after I install the new ends. I can't get time to have the front end aligned at a shop for at least a week. Are there any other methods I could use to get the alignment very close? Thanks! Aaron. Posted via Mobile Device |
06-13-2011, 06:16 PM | #2 | |
454 MAKES IT ROAR
Re: Tie rod ends and front end alignment
Marking a line on the tire and measuring front & back is the way to go, about a 1/8 toe in, done right and you shouldn't need to go to the alignment shop.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
06-13-2011, 08:38 PM | #3 |
its all about the +6 inches
I measure the distance from zerk fitting on the inner, to the zerk fitting to the outer, then make the new one the same length.
06-14-2011, 02:59 AM | #4 |
Thanks guys! I will try a combination of both!
06-14-2011, 09:37 AM | #5 |
Active Member
And you could also try the counting the threads method by counting how many revolutions it takes to remove it. I always lose count.
06-14-2011, 09:43 AM | #6 |
i run 1/16 " of tow on 30's But thats just me. I wouldnt run anymore than 1/4 on a normal size tire. and i would do 1/16 at the least.
And as far as method goes, i scribe the tires and get a buddy to help me measure it. make sure your accurate were you measure! First time i did it my friend kept moving the measuring tape up and down every measurement!
85 C10 LWB 305ci - 700r4 - 10 bolt - 3:08 gears Collecting parts for a 'mild prerunner" |
