Always a work in progress
Rebuilding front/rear suspension/brakes
I want to rebuild the suspension/brakes on my 85 when I get back from Af-hell-istan and would like my list scrubbed for anything I missed.
Front: Poly Graphite front end rebuild kit from P-S-T: 2 Upper Ball Joints 2 Lower Ball Joints 2 Outer Tie Rods 4 Polygraphite Control Arm Bushings 2 Upper Control Arm Bumpers 2 Lower Control Arm Bumpers Cpp 2.5" Drop Spindles Coil Springs(Moroso Trick) Rancho 9000 adj shocks New Rotors w/D52 caliper kit Wheel bearings CPP Manual brake Master Cylinder/Proportioning Valve Rear: Disassemble, clean, and reassemble leaf packs Polygraphite leaf/shackle bushings Install rebuilt ford 9" with axle perches for a flip Wilwood Dyna lite rear Disc Brake kit Rancho 9000 Adj shocks (relocated in front of the axle) Cal Tracs Universal Splined Sway bar kit from S&W I am looking for a good ride that will perform well on the street and strip. If there is anything else I missed or you suggest I do please let me know.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
Re: Rebuilding front/rear suspension/brakes
Are the steering box, idler and pitman arms tight?
I will have to check that when I get home. The steering didn't seem sloppy at all from what I remember.
Pick up a set of solid tie rod adjusters like these:
http://www.google.com/products/catal...d=0CFAQ8wIwAA#
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
Are drilled and slotted rotors worth the extra $$?
