Old 04-01-2003, 08:38 PM   #1
bad71chev
starter solenoid
does anyone have the wiring diagram or know the porcedure for wiring in one of those other solenoids (f#%d) thanks kc
formerly kfc282000 http://communities.msn.com/bad71chevy/shoebox.msnw
71 c10 fleetside a/c ps pb 305 700r4 hooker super comp headers,mild z28 cam, frt sway bar, kyb/air shocks, new stereo, painted gm white, 3;73 posi, 27 5/60 15 rear 245/60 15 frt, dropped 3 1/2" frt 4" rear interior is next.
if gas stays like this the big blocks goin back in....
bad71chev is offline   Reply With Quote
Old 04-01-2003, 09:37 PM   #2
Class of 69
Class of 69's Avatar
The remote solenoid has two large terminals. One cable from the battery to either one, and a cable from the other to the starter. They usually have two small posts also, but you only need to run the keyed power to one of them to engage the solenoid. Can't remember which one, but run a small wire from the battery post to each of them, one at a time, after the main cables are on, and you will know very quickly which one to key up.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 04-01-2003, 09:50 PM   #3
69NEVADACHEVY
it will be the one with an "S" on it. Don't forget to jumper the solenoid on the starter also.
69NEVADACHEVY is offline   Reply With Quote
Old 04-02-2003, 12:03 AM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
Just like they said. battery pos cable to solenoid, then cable from solenoid to starter. Jumper wire from starter + post to the S post on your chev starter(remove purple wire that was there). Purple wire will now connect to the ford solenoid at the S terminal. If you are running points instead of HEI you can run the yellow coil wire to the R terminal of the Ford solenoid or keep it on the Chev solenoid. They both do the same thing.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 04-02-2003, 09:54 AM   #5
bad71chev
thanks for the help guys, it works!!! is this board great or what, kevin
